| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
A preamp that I'm restoring currently has a couple of 10µf bipolar electrolytics at the output of one gain section. I want to replace with a decent film cap. Voltage rating is unimportant (less than 10V DC on the cap).
Usually in situations like this, I end up settling for a Black Gate because of size constraints. However, in this instance I actually have quite a bit of room to work with. What I do find, however, is that in this size catagory that all I really have to work with are basically speaker crossover caps (auricap, Hoveland, Musicap, etc, etc). I would rather find a cap that is designed to be used for what I need, rather than use a speaker cap internal to my amp. Perhaps my hesitation is unfounded and I may have no choice other than using a crossover-type cap (and if so I lean towards a auricap). But it seems as if there ought to be more choices.... Any ideas?? |
#2 |
Banned
i use http://www.wima.com/
#3 | |
But my personal preference would probably be MIT RTX (although quite expensive in this value)
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 | |
diyAudio Senior Member
With only 10VDC bias on their plates I also doubt they'd sound their best here. Maybe some low voltage Wimas ( 63 V is the lowest for filmcaps IIRC) could work better here. I never really compared so take this at face value. Cheers,
Frank |
#5 | |
Banned
#6 | |
Would you have a source for good quality low voltage polypropylene caps ( not SMD) ? TIA. Cheers,
Frank |
#7 |
Peter..
I'd love to slap a Panasonic polypropylene in there. Where am I gonna find a 10µf cap though?? The biggest I can get at Digikey is a 4.7... |
#8 |
I thought they had larger values available. You can either parallel two of them, or use just one 4.7u. This value isn't usually very critical and lower value should work fine as well.
#9 |
Parallellling is a last resort...and I'd hate to go smaller...it would bug me.
Might be doing the Auricap thing after all.... |
#10 |
Just out of curiosity where did you find the Panasonic film caps in the Digikey catalog? I see the Aluminum Electrolytic Caps that are normal sized (like FC,EB,KS series), and they also have film caps that go up 10um, but they are real little kinds, those rectangle shaped ones...probably not what your looking for.
| paralleling film caps with electrolytic caps | jarthel | Power Supplies | 381 | 10th March 2012 08:13 AM |
| Film caps | jimi42 | Parts | 0 | 29th July 2005 03:27 PM |
| Wima film caps | zerodigit | Parts | 2 | 31st October 2003 12:24 AM |
| FILM Caps to assist Big ELYT Caps | gromanswe | Parts | 0 | 9th July 2002 08:16 AM |
| Page generated in 0.11116 seconds (77.56% PHP - 22.44% MySQL) with 10 queries |
