Routing guitar signal between two paths?
Hey guys. So I'm trying to design, an idea of which is below:
http://quickid.net/switching%20circuit.jpg The idea is that when the Xbee receives the "ON" signal, it will control the switching circuit, sending the input signal (guitar) into the A/D converter of the microcontroller. When the Xbee receives the off signal, it will control the switching circuit, sending the input signal around the microcontroller to the output (true bypass). The question is: what should I do for the switching circuit? haha. I'm not really sure how to design this / if there are any adequate ICs. I was thinking of using a relay, but I'm worried about the possibility of "pop" etc that could occur given the electromechanical nature of relays. Thanks in advance! |
Woops that was supposed to be "Hey guys. So I'm trying to design a circuit, an idea of which is below."
Relays don't make pops because they ar electromechanical, they make pops because the circuits they switch are left unterminated or improperly terminated. That means when the contacts close, two things at differeing DC voltages are connected. SOme cap has to charge or some other action has to occur to get those voltages the same, and a pop results.
SO you want an AB switch that is relay contriolled instead of stomp switch. I am not familiar with Xbee, can you link a schematic or at least enough tech specs to know what we are working with? If it is a remote control system, and it already has an output that toggles off and on that we can use, then interfacing it to a relay should be simple. If you just can't abide relays, then a similar circuit could be made with JFETs, or even a couple op amps. |
So basically i just need to be able to switch between two different channels, like an A/B box, using 5VDC to put the signal down one path, and 0VDC to send the signal down the alternate path. Does this help at all? |
So the "control" you see in the image is really just a pin on a microcontroller, likely an ATMEGA168, going either high or low, depending on what the Xbee tells it to do.
I would love to hear more about your op-amp and JFET possible solutions; as I'd really rather use something like that than a relay. Thanks again for your post. I wish I could just edit my above post and put this stuff in, but for some reason diyAudio doesn't seem to allow editing of posts. |
Something like this? Three Ch not 2 but you could use it.
http://focus.ti.com/lit/ds/symlink/cd4052b.pdf |
As RJM1 posted, the old CMOS analog switches such as 4066 will work, if you bias your audio into the switches at 2.5V, midway between ground and the power supply. That'll work but you need to add capacitors and resistors, and do it "right" so there will be no popping on switching, bla bla bla.
There are other, more modern solutions that allow +/-15V (common op-amp power voltage range) signal range and still have 0 to 5V control voltage range here: Analog Switches and Multiplexers - Maxim |
something like this MAX4714 0.8-Ohm, Low-Voltage, Single-Supply SPDT Analog Switch in SC70 - Overview seems to be just what I'm looking for, if it was in DIP.
I'm also not entirely sure what the various "on resistance" parameters mean / if they're at all important to me. For example, with the MAX4714 (linked to above), it says the Ron = 0.8 ohms max for a 3v supply... What's that mean? |
| All times are GMT. The time now is 10:26 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
