polyprop caps, metalized or foil? - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th March 2011, 11:15 PM   #21
SY's Avatar
If you're talking about standard film caps from major manufacturers (e.g., Wima, Panasonic...), then that's largely true. When you bring in boutique caps from "audiophile" sources, then many of these problems can appear.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th March 2011, 11:58 PM   #22
My definition of distortion is the introduction of frequencies that were not present in the original signal. Capacitors are in the signal or feedback path. What source of distortion is greater than effect of DA?
Old 9th March 2011, 12:12 AM   #23
SY's Avatar
Could you please give an example of the distortion you're talking about?
Old 9th March 2011, 12:27 AM   #24
mach1 is offline mach1  Australia
mach1's Avatar
Getting back to the original question.
With respect to coupling caps I don't think you can make a blanket statement that one type is superior to the other. The general assumption is that film and foil are superior; but I have certainly heard some pretty good metallised caps and some pretty dire foil ones.
I think the outcome is more due to materials selection, manufacturing processes and QA.
'Symmetrical equations are good in their place, but 'vector' is a useless survival, or offshoot from quaternions, and has never been of the slightest use to any creature.' Lord Kelvin
Old 9th March 2011, 01:27 AM   #25
The distortion that results from using caps with high DA (electrolytics - ceramics), as opposed to using low DA caps like polypropylene film in signal or feedback path.
Old 9th March 2011, 02:36 AM   #26
SY's Avatar
Well, that's what's used in the signal path of my sound card (input cap, output cap, feedback cap), but the distortion is below 0.001%. Ditto the nice solid state power amp I use in my lab (an old school Adcom 555, not quite 0.001, but down there).
So can you give a different example?
Old 9th March 2011, 03:26 AM   #27
Absolute distortion measurements can be misleading; did the distortion change when you replaced high DA caps with low DA ? Did the sound character of the equipment change?
Old 9th March 2011, 03:57 AM   #28
SY's Avatar
At those ridiculously low levels, I doubt that I could measure or hear a change. In any sort of practical amplifier circuit, the caps are rarely the limiting factor in distortion- tubes and transistors are highly nonlinear devices in comparison.
Old 9th March 2011, 08:02 AM   #29
Elvee is offline Elvee  Belgium
Elvee's Avatar
Then, you're talking about non-linear distortion.
DA does not belong to that category.
Non-linear effects are caused by a change in permittivity as a function of the applied electric field, and they depend upon the absolute level of tension applied to the capacitor. DA remains the same at 1mV or 1KV.
If you use a 50V mylar capacitor at AC voltages of several volts, some non-linear effects will be noticeable, but if you use a 1000V part in the same conditions, the effects will practically vanish.
Old 9th March 2011, 09:09 AM   #30
wintermute's Avatar
Walt jung's article Picking Capacitors part II has a description of how DA causes "distortion" of audio signals. Certainly to a layman like me it seems to be plausible. The attachment is just a small extract from the article. Both part one and part two are available on Walts site, where he gives quite a thorough (I thought) coverage of why you would want to use various types of capacitors in preference to others.
I've yet to read Cyril Batemans Understanding capacitors articles.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
FS two 80uF polyprop in oil caps QSerraTico_Tico Swap Meet 0 25th June 2007 04:41 PM
FS: computer grade electrolytics & polyprop caps len_scanlan Swap Meet 6 31st October 2006 06:15 PM
anyone ever used metalized polypropylene caps from Digi-key? crtubes Parts 6 16th September 2005 12:47 AM
paper in oil vs. polyprop. caps for AlephP/BLSZ? malisz Pass Labs 5 2nd October 2003 07:51 AM
Are these polyprop caps (pic)? capslock Parts 18 10th April 2003 11:56 AM
Copyright 1999-2017 diyAudio
