Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th March 2011, 04:05 PM   #1
Default Help with small transformer please
Hi guys
I need help with small toroidal tranformer with typical regulation of 35%.
I need 15v of this 7va toroidal. But the open circuit measured 20v
Is there anyway to bring down the voltage? When its underload, it only went down to 18v. How to make it went down to 15v? I cant load it with more.
Thanks in advance
Erwin
Old 6th March 2011, 04:44 PM   #2
Is the secondary wound on top of the primary? You could try unwinding some turns....
Old 6th March 2011, 05:01 PM   #3
Hi viactoriaguy
Thanks for the respond forget to mention that its a pcb mounted type which is impossible hacking into the sealed case
Are putting resistors in series with the secondary output would help bring down? If possible. Whats the formula to calculate the resiators value?
Erwin
Old 6th March 2011, 08:04 PM   #4
Erwin: Show us your circuit? Most will be able to handle that 3v difference! E
Old 6th March 2011, 08:16 PM   #5
There's probably a regulator in the DC side of the circuit that should handle the extra voltage...you might need a bigger heat sink on the regulator if it needs to dissipate more energy.
Need small SET transformer (12B4) Pano Tubes / Valves 31 29th May 2009 12:04 AM
small transformer ferrite source PM650 Parts 0 25th December 2007 10:49 PM
How about this small # toroidal transformer? bigdogwang Parts 4 22nd November 2007 01:10 AM
One big transformer or several small ones. Which is better? DaBit Power Supplies 1 24th June 2007 05:08 PM
Transformer wires too small? drfrink24 Chip Amps 3 4th March 2005 06:45 PM
Page generated in 0.07371 seconds (83.05% PHP - 16.95% MySQL) with 10 queries
