Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd March 2011, 06:14 PM   #1
Bob Richards's Avatar
Default touch plate switches???
I'm going to build a line preamp and would love to use touch plate switching technology. I researched chips that would support this, but they all seem to require a CPU. I'm trying to find touch plate chips that put out a separate control voltage for each touchplate, something I can buffer and drive a small latching relay with. or at least a binary output that I can decode with a binary to base 10 converter chip. Any help on this would be appreciated much.
Old 2nd March 2011, 07:18 PM   #2
Hi Humdinger
If you search for capacitive touch sensor ICs you should find plenty. Have a look at this one for example:
ATMEL|AT42QT1010-TSHR|SENSOR, TOUCH, CAP, 1CH, 6SOT | Farnell United Kingdom
Old 3rd March 2011, 12:44 PM   #3
macboy is offline macboy  Canada
The Azoteq IQS127D implements a single touch- and proximity-sensitive button (even through a substrate like glass or plastic) and has simple to use "active on" outputs. One problem is that it comes only in a tniy little SOT-6 package, and another problem is that it's hard to find. One of my favorite component/gadget stores carries it in a pack of 5 including DIP adapters.
Old 3rd March 2011, 07:14 PM   #4
Thanks much. I've also found a few others on the web that appear to be useful for someone who doesn't write code. I've wanted to use touchplates for decades, I think since I saw the movie A Clockwork Orange in the late 60's. Now I just need a good clear conductant that you can paint onto frosted plexiglas. That way I can backlight the touch plate/knobule fully, with an LED. Anyone know where I can get paintable (dipable) clear conductant? This is going to be SO COOL!!!
Old 3rd March 2011, 07:33 PM   #5
I don't know about clear conductive paint, but you can buy sheets of clear acetate coated in Indium Tin Oxide - I think I even got some free samples from somewhere. You could cut pieces out and place them behind your perspex panel. Alternatively you can make electrodes from extremely fine wires which would be practically invisible.
Old 3rd March 2011, 09:06 PM   #6
Steerpike's Avatar
If you want a 'touchable' transparent front plate, you might try infa-red LED/phototransistor reflective detectors. Then you just have a piece of tinted plastic or glass with no conductors required.
E.g. http://docs-europe.electrocomponents...6b802aff23.pdf
Steerpike's Toybox
Old 4th March 2011, 10:55 AM   #7
Itsmee is offline Itsmee  England
Itsmee's Avatar
This might be what your looking for
Electronics Projects Vol. 22 (With CD) - Google Books
or you could use a PIR detector
Top quality main switches for audio-hifi comp (Rotary and Pushbutton Power Switches) tiefbassuebertr Parts 12 10th March 2010 04:14 PM
EL84 PP using 5K plate to plate primate OPT jmillerdoc Tubes / Valves 5 9th March 2010 09:14 PM
A simple way to create dual(or more!) rotary switches out of single rotary switches stappvargen Pass Labs 14 16th April 2004 11:33 PM
Subwoofer Plate Amplifier Base Plate supplier? jwells777 Parts 1 11th May 2003 07:40 AM
Page generated in 0.08543 seconds (74.81% PHP - 25.19% MySQL) with 10 queries
