| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi folks. I was advised to replace the two OpAmps in my Pioneer PDS802 with two of the high quality LM4562 which are DIL 4 pins per side. They arrived today and with enormous enthusiasm I took off the cover and searched for the two OpAmps to remove. After many checks in every little nook and crannie, I did not find any OpAmps of that configuration. What I DID find were two "Single line" ic's labelled NJM5532SD.
Could you please tell me if I am supposed to somehow adapt the LM4562 to replace the 5532SD's or have I ordered completely incorrect items. If incorrect, could a member please let me know what is the best IC to buy for replacement of the 5532SD's. I have just earlier today completed replacement of ALL electrolytics and using the analogue out-which is my preference-I got better impression of dynamics and noticeably increase in same given volume as set before the re-cap job. So I am definitely going thru with the works (as funds permit over time that is!!) Thanks guys.. |
#2 |
The 5532 is a common dual opamp, the LM4562 it's successor really. As long as the package is correct (DIL or SMD) then it's a straight swap.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
Just re reading your post... you say SIL (Single in line). If so they won't fit.
Do they look like this ? Google Image Result for http://www.donberg.ie/pics/b/ba_15218n.jpg
#4 |
Mooly the link you gave shows the configuration of what is fitted in the player-all pins in one line.
The LM4562 has 4 pins per side and is about 1/4 of an inch or so long. So question is Can I get a LM4562 in the same configuration as the IC on your link? |
#5 |
My data sheet suggests not.
tbh the SIL package is a bit rare these days. If you are into making PCB's it's easy to etch some adapters or buy some (check the connections are correct first and they are for dual opamps). Found these. Parts & kits You could even hard wire them if needs be I guess.
#6 |
You can easilly do an adapter , even on strip board .... I did some 2 single opamp to one dual opamp boards a few years ago and they worked well ....
#7 |
Minion yeah I think I will do a hardwire. But tell me this if you will..The LM4562 has pins 1 to 8 ......yet the 5532SD has NINE pins..????
#8 |
The nine pin package has pins 1 and 9 internally connected.
Look at the data sheets here (the packages) and make sure you understand Imagine cutting off pin 1 and then renumbering all the remaining pins 1 to 8 (rather than the original 2 to 9) Your 9 pin here (scroll down to the block diagram) http://www.datasheetcatalog.org/data...nic/AN6551.pdf Standard dual opamp 8 pin dil, http://www.datasheetcatalog.org/data...A_SA5532_3.pdf Edit... You may need to physically link with wire 1 and 9 on the PCB if circuit continuity depended on the "wire" in the opamp. A quick look at the PCB should confimr whether that's needed.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. Last edited by Mooly; 2nd March 2011 at 06:34 AM. |
#9 |
Ah Mooly you are a lifesaver mate. I looked at the diagrams per your links and "By Jove I think I've got it".... Many thanks for yur gr8 help. Cheers
#10 |
That's good.
Do you know how you will fit them ?
| Any advice on this opamp? | andyoooooobun | Digital Source | 5 | 20th February 2011 01:48 AM |
| CD player opamp upgrade -advice needed | stevew7280 | Digital Source | 9 | 8th October 2010 06:02 PM |
| Opamp I/v For Ad1865 Need Advice | rubydac | Digital Source | 0 | 21st February 2008 06:24 PM |
| Need buying advice from PA guys. | Cal Weldon | PA Systems | 3 | 7th January 2008 10:25 PM |
| Computer guys help needed- piping audio thru network.... | eRiCdWoNg | Everything Else | 9 | 18th December 2003 01:36 PM |
| Page generated in 0.09862 seconds (78.45% PHP - 21.55% MySQL) with 10 queries |
