Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
where to find a 10 led bargraph like this one?
Old 16th February 2011, 03:54 PM   #1
Joseph R is offline Joseph R  Switzerland
Default where to find a 10 led bargraph like this one?
I'm looking for some led bargraph like this one with the black led holder. Just the bargraph not the PCB.
Does somebody know where to buy?
Old 16th February 2011, 08:36 PM   #2
Enzo is offline Enzo  United States
I would find some commercial product that uses them. I work in pro audio, and many mixer have LED strip VU meters. Older ones tended to be larger, but I don't know what size you want. Large console mixers to little DJ mixers use them, and you could probably source one from some of those companies. I would call Peavey, but you don;t appear to be in th USA.
Hunt in general for "LED bar graph arrays" or similar
I see some at Jameco.
Digikey sells them, go there and search "LED array", then check the 1x10 on the filter parameter list for some examples.
Same at Mouser, search LED array and use the filter.
Old 18th February 2011, 08:36 PM   #3
Thanks Enzo,
I did find some at SSA-LXH1025GD - Lumex - SSALXH1025GD - datasheet and
SIL LED Bargraph Displays
I did not search the right terms in the begining, I was stuck into vumeter led bargraph.
where to find a 10 led bargraph like this one?Hide this!Advertise here!
Nixie bargraph as a audio VU-meter wim Tubes / Valves 11 27th March 2011 08:13 PM
Lcd bargraph Leon08 Analog Line Level 1 25th January 2011 01:49 PM
Bargraph and clip LED's nigelwright7557 Solid State 0 24th November 2009 12:42 AM
Where do i find an LED Bar? guitarguy12387 Parts 6 7th July 2008 02:07 PM
