Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th July 2003, 05:09 PM   #1
Default Sound Blaster Live Processor
I've done some research on the subject and want to build a surround sound processor/preamp. I want to take a sound blaster live card & run a dd or dts signal to it then take the the analog outputs and matrix them together to get 12.1 surround sound. There have been some post on the sound blaster live cards before, but nothing quite like I'm talking about. If there is anybody that has done something like this, has an idea on how to, or is interested please let me hear from you.
Old 28th July 2003, 05:18 PM   #2
tiroth is offline tiroth  United States
Buy an extigy.
Old 28th July 2003, 06:15 PM   #3
purplepeople's Avatar
Tomlinson Holman only just introduced 10.2 - how would you implement 12.1? Are you talking about multiple surround speakers with digital delays like in the big theatres?
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 28th July 2003, 09:15 PM   #4
Somewhat. Iwould take the rear to channnels and matrix them together for a center rear channel. And do kinda of a delay for the other channels.
Old 28th July 2003, 11:36 PM   #5
What you have here is typical of the 6.1 systems, such as the Dolby Digital EX system or the DTS Neo standard. They also specify sending the matrixed centre surround channel to 2 centre rear speakers to keep it out of the "dead" spot directly behind the listeners' heads.
Where are the other 6 speakers?
:)ensen.
Old 29th July 2003, 03:12 AM   #6
If it is possible I would like to mix the Front left with the Rear Left to get a Left center channel so fourth so on. ( The idea actually came from a sound and vision mag talking about realistic sourround sound).
Old 29th July 2003, 03:18 AM   #7
The whole multiple channel thing is just an idea for now, what I really want to know is if it is possible to hook up one of these cards with out using a a computer and run a Dolby Digital or Dts signal in and get discrete anolog outputs ?
Old 29th July 2003, 08:18 AM   #8
Hi AA,
There were a couple of other recent threads that dealt with a similar application and you may want to look them up.
soundcard with SP/DIF coaxial out
$30 Active Line-Level Crossover
AC97 codec replacement?
I know the on-board sound of my Gigabyte motherboard can decode AC3 and output 5.1 analog so I imagine that all these basic DSP chips will have similar features. There will likely be some programming, especially if you want to use the card without plugging it into a mobo bus and you will likely also need some kind of memory to store your program.
That said, most consumer sound cards don't have the analog quality to compete with a well done analog 2.0 matrix decoder done. Most of them barely have SNR of 80dB so you may be better off getting a cheap used Yamaha receiver or try this.
http://www.sound.westhost.com/project18.htm
As for trying to mix L and LS to get a left centre channel, you will only get success if two things happen. 1) The mastering engineer intended there to be such a signal and encodes that signal into both the L ans LS channels. 2) You know how that information is encoded, if it's there.
The first situation is highly doubtful as the mastering is (now) usually done under strict guidelines for AC3 or DTS decoding.
HT vs Stereo - an issue not covered?
In the second situation, you'll need an option for both summing or difference signal and then be able to boost or attenuate the signal by 3dB.
:)ensen
How to achieve the LIVE sound? Like you ARE THERE? rjp366 Multi-Way 52 12th October 2009 04:39 PM
surround sound processor using a PIC BarryD54 Digital Source 0 7th July 2008 09:11 PM
Krell or Mcintosh Surround sound processor gto127 Digital Source 0 8th January 2008 11:33 PM
True Rta with sound blaster extigy problem ostie01 Multi-Way 2 6th May 2006 09:26 PM
Hifi Link vs Sound Blaster Live 24 bit External Hara Digital Source 0 30th January 2006 10:44 PM
Page generated in 0.09678 seconds (74.93% PHP - 25.07% MySQL) with 11 queries
