Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
part substitute, need help fast.
Old 7th February 2011, 06:33 PM   #1
pulsardet is offline pulsardet  Canada
Default part substitute, need help fast.
Hi there, I have a nearly complete cross-over for my new speaker that I built
this is exactly what I built Parts Express DIY Project
The only problem is I miss the 8.0 mh 18 awg I core inductor, everything is done, enclosure, the cross-over is nearly finish too.
What would be a substitute for this 8.0 mh 18 awg I core inductor since it's the only part I don't have and it's back order for I don't know how long
Thank you , for your help and It's might sound has a easy question, but I don't know about anything about electronic, other than solder this to this and voila.
Old 7th February 2011, 07:24 PM   #2
Mooly's Avatar
See your thread is OK now
The inductance is important as it's a crossover network.
Something like an 8.2mH would be OK if you can source one locally.
--|LSIF-820|8.2MH HIGH POWER CROSSOVER INDUCTOR | CPC
Old 8th February 2011, 01:48 AM   #3
Enzo is offline Enzo  United States
The inductance matters, but you can use a different coil, it doesn;t have to be the exact same core construction.
If your 8mh #18 is on backorder from PE, ASK them when it will be coming in. If you don't want to wait, look at other 8mh options, heavier wire, different core, etc.
Try other sources like MAdisound maybe.
Old 9th February 2011, 02:22 AM   #4
I did order the part even if it's back order, I find a similat part localy to be able to run the speaker until the back order part, come in.
Thank you for the info it's very usefull for someone like me, since I don't know much about electronic.
part substitute, need help fast.Hide this!Advertise here!
No Substitute for... mcd99 Subwoofers 8 16th January 2011 02:58 PM
Help with part substitute HIPCHECK Parts 0 6th June 2008 02:03 PM
what part can take the place of ST part VB408B completely peterchen88 Parts 0 8th September 2007 06:45 AM
part# for spare part for CDM-1 wanted joe Digital Source 5 20th March 2007 08:59 AM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 10:00 PM
