Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th January 2011, 12:17 AM   #1
Default Need technical advice on battery and voltage problems
Hello,
I have an OLD tape recorder that I wanted to make portable, so I cut the plug and wired a 9 volt battery up to it. It may seem pointless, but It is important to me to use this particular "memo-scriber" machine. My problem now is that I can't afford to buy that many nine volt batteries. I am not looking for great sound, the amp is made to run on batteries and works fine, I'm just looking for a longer street life. I have a couple of 12V batteries around, is there an easy way of converting it to 9V and keep rocking out longer? I know Lithium batteries last longer... is there such a thing as a rechargeable industrial 9V battery?
I have an inverter, but it's massive and I would rather not have to go that route.
Obviously I am no electrician, but any help with this would be greatly appreciated.
Old 29th January 2011, 12:51 AM   #2
All lead-acid batteries are composed of 2 V cells. You can use five of them to get 10 V.
You can tap into the 12 V units (six cells) or even cut them up.
How close to 9V do you need to get? The 2 V cells will supply about 2.3 V while charging. You can add large diodes in series to drop about 0.6 to 0.75 Volts per diode.
Old 29th January 2011, 12:53 AM   #3
Enzo is offline Enzo  United States
Make up a battery pack of larger cells like C or D size.
Technical advice needed on a Sanyo DAD-8 Dateq Digital Source 3 21st December 2009 07:29 AM
emulating concert visuals with a LARGE format LED display, any technical advice? thadman Everything Else 7 25th June 2009 11:57 AM
Battery for Cathode Voltage? markw51 Tubes / Valves 15 12th December 2006 02:53 PM
Voltage Regulation from a battery bigphil Power Supplies 9 14th October 2006 03:44 PM
Page generated in 0.06051 seconds (80.60% PHP - 19.40% MySQL) with 10 queries
