| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#3 |
If its an input, you should be able to tell be measuring the resistance of the center pin and outer shell.
If its an output, you'll have to look at the buildout resistor in the circuit. For most applications, it doesn't matter. In broadcast TV both are used interchangeably. |
#4 |
The important thing is not the connector, unless you are working at high RF frequencies. The cable needs to match the presented impedance unless the cable is quite short.
#5 |
It's not about the cable, it's about the connectors.
The center pin of the 50 Ohm and the 75 Ohm connectors are of a different diameter. So if you connect a small male to a large female you have a poor connection. But if you connect a large male to a small female then you damage the female! That all sounds so dirty. For the short cable lengths and low frequencies that many of us work at, characteristic impedance is no big deal.
Kevin |
#6 |
There have been huge debates about that, which were inconclusive. Anecdotal evidence points both ways. Official drawings suggest the pins are all the same, with the impedance difference coming from including or omitting the plastic dielectric.
#7 |
Wow "DF96" I just learned something from you. I had always though that it was a mechanical size difference issue and we would warn the equipment installers about the damage that it would cause.
But Amphenol Connectors has a page: Amphenol Connex- BNC Connector Series Two distinct types of 75 Ω BNCs are available, and both mate with each other and with 50 Ω BNCs.
Kevin |
#9 |
50 ohm pin (and female part) has smaller diameter, 75 ohm pin/female has larger diameter, as Speedskater wrote. There might be some difference in the insulator part, too.
#10 |
is for the hole for the center conductor to go into. Fifty ohm cable center conductors are smaller than 75 ohm cable center conductors. Obviously the larger center conductor will not fit into the smaller pin.
BUT, I have done this. You can solder the pin on to the center conductor. Many years ago I attended an ADC seminar where they recommended soldering the pins on to the center conductor for digital applications. It seems that it reduces reflections at high frequencies. |
| Are these connectors bnc 75 ohms? | merlin el mago | Digital Source | 8 | 4th June 2010 11:32 AM |
| Changing a deemphasis from 50 uS to 75 uS | legarem | Analogue Source | 13 | 12th March 2010 05:51 PM |
| F-connector vs. BNC | pooge | Digital Source | 6 | 2nd August 2006 08:53 PM |
| 75 and 50 Ohm cable ? | jim | Everything Else | 10 | 11th March 2004 09:21 AM |
| BNC connectors (50 and 75 ohm) vs RCA on cd transport and DAC | Dr.H | Digital Source | 10 | 28th June 2003 08:41 AM |
| Page generated in 0.10140 seconds (76.92% PHP - 23.08% MySQL) with 11 queries |
