Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th January 2011, 08:35 PM   #1
toufu is offline toufu  United States
Default Transformer Question
If a construction asks for 4x9v AC. Could I just use a single 9v transformer if the wattage is big enough to supply all 4 AC input? Thanks.
Old 19th January 2011, 08:43 PM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
Depends. If you show a schematic, we could find out...
~Tom
Old 19th January 2011, 09:15 PM   #3
db! is offline db!  Canada
You should be able to unless the supplies needs to be isolated from each other. When you 4x9V, do you mean four 9V taps on a single transformer or four 9V transformers?
Old 19th January 2011, 09:33 PM   #4
Is there a difference between four taps on a single transformer or four 9v transformers?
Anyways, I am trying to build Oliver's TDA1541 DAC, it asks for 3x12V AC at 1amp each. Can I just get a 50VA single 12V transformer to feed all three?
Thanks for the quick reply.
Old 19th January 2011, 09:44 PM   #5
From what I understand, a separate power source/transformer should provide "cleaner power" since there is no crossover interference(I think that's the tech term). Depending on the sensitivity of your circuit, you may be able to get away with a multi-tap transformer...
Is this the project you were looking at?: My take to the "Reference" TDA1541A DAC with I2S-BUS architecture
If so, you will need isolated supplies...
Old 19th January 2011, 09:45 PM   #6
Yep, that's the project.
Transformer question slowlearner Class D 7 1st January 2011 10:27 PM
transformer question abiedoodles Parts 3 10th February 2008 11:35 AM
transformer question xcortes Chip Amps 0 31st October 2004 05:04 AM
Transformer Question Rex Solid State 4 22nd February 2004 08:37 PM
Transformer question amo Chip Amps 16 27th January 2004 01:50 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
