Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th January 2011, 09:18 AM   #1
Default Murata 7805SR - worthwhile upgrade over standard 7805 or 317?
Other than increased efficiency, would you expect an audible improvement from using a Murata 7805SR (or similar high efficiency switching regulator) in place of a standard 7805?
http://www.murata-ps.com/data/meters/dms-78xxsr.pdf
How would you expect this to perform compared to a properly implemented 317 with adjust cap?
I have a few of the Muratas on the way and will try these in a couple of DACs and Tripath amps. I'd be keen to know if others have had success with these (or not!).
Old 12th January 2011, 10:02 AM   #2
Send a message via AIM to DigitalJunkie
Hmm.Those look kind of neat,limited to 500ma (400ma for the 12V version) though.
Old 12th January 2011, 10:34 AM   #3
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
this might be a problem in some applications:
8. Dropout Voltage: 78SR series regulators described in this data sheet
specify a minimum input voltage at which full-load accuracy and output
regulation are guaranteed (7.5V for 7803SR-C and 7805SR-C, and 15.0V
for 7812SR-C
). However, these devices will stay in regulation at lower
input voltages if they are operated at less than their rated loads.
The following dropout-voltage data, derived from sample testing
performed at an ambient temperature of +25°C with resistive loads,
should be used for information purposes only. For these tests, a unit was
considered to be out of regulation when its output changed by more
+/–0.005Vdc from its nominal value. All voltages were measured directly
at the regulator’s I/O pins.
Old 12th January 2011, 03:19 PM   #4
Lots of hf ripple, at frequencies where opamp supply rejection is falling fast.
Nothing is said about magnetic field from the inductor. I don't think such a low profile inductor is going to be well shielded.
Old 25th April 2011, 02:37 PM   #5
dejanm is offline dejanm  Austria
Any news about the effect of using Murata instead of 7805 ?
Worthwhile to upgrade from SB Acoustics SB29 to SS AirCirc 6600's? Tyson Multi-Way 11 29th July 2010 07:44 AM
When to use 317 and 7805? Sunsun22 Power Supplies 8 6th April 2009 06:47 PM
Use standard 317 or 317L? Christer Parts 16 7th July 2006 06:41 PM
murata caps in mesa boogie footswitch rockstudio Parts 2 16th October 2005 08:25 AM
Wide band Common mode chokes by Murata Dr.H Digital Source 2 3rd July 2003 03:29 PM
Page generated in 0.08466 seconds (74.21% PHP - 25.79% MySQL) with 10 queries
