Asc/Angela vs Black Gate caps - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd July 2003, 08:23 AM   #1
Default Asc/Angela vs Black Gate caps
Hi ,
Looking for opinions on the ASC/Angela vs. BG in a JELab 300bdx setting?
What are the pros and cons of each type of cap? Are the ASC reliable?
TIA
Old 23rd July 2003, 03:36 PM   #2
cdeveza is offline cdeveza  United States
ASC Caps are the same ones Allied Electronics are selling(cheaper too), they are motor run caps, Oil type, although not paper-in-oil. I have used them on power supplies and ultra-path caps, they are very reliable. Black gates are electrolytic, the only BG I have used are for cathode-bypass, I have not used their power supply caps(unreasonably expensive, IMHO). Anyway, as for reliability, I think the ASC will last longer as electrolytic will tend to dry-up, although, in a very long time. Sonically, depending on where you use them, they do sound different from each other. Being one is electrolytic and the other Oil Polypropylene type.
Alex Deveza
Old 23rd July 2003, 07:22 PM   #3
Default Asc vs BG
In my opinion there is no doubt BGs sound better !
I tested one against other in a preamp power supply . The only
problem , they are expensive . ASCs are a cheap alternative , i m
using them in my amp power supply, wish i could buy BG instead .
Old 23rd July 2003, 07:40 PM   #4
HeadSh0T's Avatar
if you can get any, try elna cerfines. .they don't cost as much as black gates and are excellent if not better.
they don't have the extremely long break-ins as BGs have and if you don't run your amp for a while, you won't have to break them in again like you do for BGs.
Of course, if you can afford it, go for film caps over electrolytic such as the large Ansar Supersounds.
Old 23rd July 2003, 08:08 PM   #5
Brett's Avatar
Default Re: Asc/Angela vs Black Gate caps
Originally posted by hardcore
Hi ,
TIA
I have a few ASC X386S series in my amps, all 100u/370vac. Sound great, very cheap, and if used within spec should last a hell of a long time being industrial grade parts.
I do not that Gary Dahl says he found they 'sang along', something I've never noticed with them.
I won't use BG's as they're stupid money for PS caps, and I try not to use coupling or cathode bypasses at all.
Old 23rd July 2003, 10:36 PM   #6
Default bg's vs ASC's
What i like more in the BG's is that the sound appears be better
as the time goes by , we can feel the headroom widening in the
process . Today i am absolutely sure that the " Heart of Muse "
thing is not fake , BG's are very musical indeed .
Old 23rd July 2003, 11:33 PM   #7
diyAudio Senior Member
fdegrove's Avatar
Thought I'd chip in...
I feel the Ansar are even better than the ASC.
Never tried the BGs so far, price and those extraordinary break-in period made me rather skeptical...add to that that I fail to see how they can beat a good filmcap...
But I could well be wrong rejecting the BGs...as a coupling cap I'd filmcaps unless an extremely large value is called for.
Frank
Old 24th July 2003, 05:01 AM   #8
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
I've used the Audio Professor (Nichicon) dual 47uF in one of my 2A3 amp to good effect.
Mostly I use Panasonic TS-UP 500V caps (i'm cheap BG is too expensive) for PSU, but my first projects were all done with a combination of Sprague Atom and Nichicon.
Old 24th July 2003, 05:56 AM   #9
Brett's Avatar
Thanks for the tip. I'd noticed these in the catalogues but hadn't bought any. I've used the Pana TSHA, TSHB and FC's in amps before to good effect. Not as good as PP's but far from ear-bleeding bad, as well as being modestly priced and small.
Been eying a sort of Manley Mahi clone to find a use for the Brooklyn OPTs I have, but no NFB and all class A and the Pana caps would actually fit in the chassis.
Old 24th July 2003, 06:38 AM   #10
THanks Guys,
How about those Sanyo OS Cons? Anyone tried them
WTB:Black Gate Caps Fast996 Swap Meet 2 11th November 2008 05:45 AM
Black Gate 'super E' caps Terry Demol Parts 99 7th September 2005 01:26 AM
Black Gate Caps - end of the road Nuuk Parts 7 6th September 2004 11:41 PM
Copyright 1999-2017 diyAudio
