| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am trying to repair my old Nad 3030 integrated amp. I would change the old pots, but I can not find the right ones. ![]() Here are all the information that I got Here's the service manual Nad_3030 service manual I really do not know where I can buy new ones. ![]() Thank you Last edited by b0ri5; 7th January 2011 at 09:18 PM. |
#2 |
The outside dimensions of the screw threads, the distance between legs, and the distance between the back of the mount flange and the leg at the circuit board level would be useful.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 |
#3 |
Do they need changing? Have you tried switch cleaner?
#4 |
Hi
I think its nearly impossible to buy them nowdays. The bproblem is the 4th wire that I think is used for loudness in your amplifier. At least its like that in som HK recievers from the 70s. So try and clean them with deoxit or something like that. There are good thread about cleaning pots |
#5 | |
I have already tried to open them but I really don't know how. They have also a wrong impedance (due to age, I think). For example volume pot now is 40k instead of 50k |
#6 |
No need to open them, just squirt it in through a hole. If you want to open them then just bend back the metal tags but be careful because you may not be able to get them back together neatly.
It is unusual for a pot to reduce in value as they are basically carbon resistors. Maybe just a tolerance issue - they might be 20%? 40K will work fine instead of 50K. |
| What i need to know about Pots? | samsagaz | Parts | 4 | 12th March 2009 04:40 PM |
| POTS! Get Your POTS! | SmarmyDog | Swap Meet | 7 | 29th October 2007 01:19 AM |
| Two pots | EAH | Chip Amps | 2 | 15th May 2007 03:28 PM |
| F.S.: Pots | Cobra2 | Swap Meet | 9 | 13th December 2005 08:08 PM |
| Alps pots vs. TKD pots? TKD worth the extra$$? | G | Tubes / Valves | 11 | 17th August 2004 04:33 AM |
| Page generated in 0.09913 seconds (81.42% PHP - 18.58% MySQL) with 10 queries |
