Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th January 2011, 04:27 PM   #11
Default Can anyone ID this cap?
Non-polar electrolytic.
Manufactured by TSI in 12th week of 1977.
Here are several similar caps in a crossover from a Triad mini-system from the mid-eighties. Note the date code: 8210 (10th week 1982)
The 200uf cap is 2.1" x 0.7". Way, way, way too small to be anything but electrolytic.
Old 9th January 2011, 06:23 PM   #12
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Mea culpa, more likely neither film nor electrolytic (imo).
They're small/large enough to be paper in oil caps.
These and Callin PIO caps were used in Altec '70s/'80s models ; Nineteen, Santiago, Santana II, Valencia, etc.
Example picture (scuse the non bipolar part)=>
Looks like Sponge Bob has killed another thread.
Old 9th January 2011, 08:13 PM   #13
QSerraTico_Tico's Avatar
It are bipolar electrolytics giving typical "English" sound.
If you replace these by plastic film caps you get a totally different sound.
Old 10th January 2011, 03:53 AM   #14
I think Jacco gets the prize on this one.
Having never (until about ten minutes ago) cut one open, I would not have believed a PIO cap could have the volumetric efficiency to pack 200uf in so small a package. However, given the low voltage rating, it appears that it is indeed possible.
Interestingly, the 2mil (0.06mm!) foil electrodes appear to be something other than aluminum. Tin perhaps? One thing is certain: they do not melt or oxidize when heated to almost white heat with a torch. Definitely not aluminum.
In any event, I think most of us would agree that these capacitors would best be replaced with ones using a more modern dielectric.
Old 10th January 2011, 04:45 AM   #15
analog_sa's Avatar
This will dramatically alter the voicing of the speaker. Maybe even for the better.
I am also surprised by the contents of the cap. Many thanks to you and Jacco.
Old 10th January 2011, 07:51 AM   #16
Send a message via AIM to DigitalJunkie
Huh,interesting. Thanks for the investigation guys! I guess I'll order up some new caps and call it good.
Please help ID Wima cap mtl777 Parts 7 25th May 2010 04:51 PM
Little help with ceramic cap ID? peace brainerd Parts 1 4th December 2008 08:36 PM
Need help - Old cap can ID atmars Tubes / Valves 5 7th July 2008 04:03 PM
ID a cap?? Jacco? mpmarino Parts 10 27th September 2007 11:55 AM
Roederstein cap ID please redrabbit Parts 5 25th January 2006 07:46 PM
Page generated in 0.09976 seconds (79.91% PHP - 20.09% MySQL) with 11 queries
