Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 31st December 2010, 11:04 PM   #1
Default 16v. caps in 15v. circuit
I have some 16v 47uf BG caps I would like to use as ps bypass caps in a 15v circuit. Is this safe to do? They are FK BGs, their highest grade. Thanks
Old 31st December 2010, 11:10 PM   #2
As long as the voltage never goes above 16V it's safe.
Old 1st January 2011, 10:56 AM   #3
marce is offline marce  United Kingdom
Standard practice for reliability is to spec a elect at 2X the working voltage. 16V will work, but I'd still go for a higher voltage to be on the safe side.
Old 1st January 2011, 12:28 PM   #4
analog_sa's Avatar
If the 15v is regulated there will be no problems.
Old 1st January 2011, 02:56 PM   #5
It is a regulated supply for the output opamps in a DAC. I am concerned about voltage spikes. These are the de-coupling caps and I do not know enough about the circuit to know if spikes are possible. Thanks for any info.
Old 1st January 2011, 03:43 PM   #6
Keeping in mind degradation of capacitor over the time, It wont be recommended. so at least go for 1.5x.
There is always a first time....
New 22u/16V WIMA film caps MKS2-XL jean-paul Swap Meet 11 4th August 2011 08:55 AM
New 10u/16V WIMA film caps jackinnj Parts 37 10th December 2010 10:07 AM
Circuit Sanity Check: +15V, -15V, +9V Power Supply miallen Power Supplies 4 18th July 2009 07:18 PM
RUBYCON ZL 16V 1500uf CAPS FS homemade Swap Meet 10 4th November 2007 01:06 AM
Which replacement caps for 47uF/16V non-polar? Sampsa Parts 0 7th June 2004 03:29 AM
Page generated in 0.07303 seconds (71.52% PHP - 28.48% MySQL) with 10 queries
