Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Where to get blue displays???
Old 20th July 2003, 08:48 PM   #1
Shaun Perez is offline Shaun Perez
Default Where to get blue displays???
I am wanting to put a display on my preamp that will read out the source but I would like it to be blue, but where do i get these blue displays?
I have searched and only found blue numbers or graphics displays requiring programming.
Please anyone who knows how to put a display in a preamp please help!!
Old 20th July 2003, 09:09 PM   #2
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
Here's my suggestion :
Since LCD display require to be controlled by either a CPU, a microcontroller or a FPGA I suggest to use a simple PIC 16F84 to control the LCD display in 4 bit mode. This is probably the cheapest way to achieve your goal.
Take a look here :
http://www.optrex.com/products/produ...archTerm=51505
If you have any further questions, don't hesitate !
Old 20th July 2003, 09:22 PM   #3
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
That is a nice Display Shaun those will look good in that project..
Old 20th July 2003, 09:59 PM   #4
thats a very nice display but i dont know how or have the equipment to make it work. is there an easy way????
Old 20th July 2003, 10:01 PM   #5
Banned
Well where in the right place. i'm sure we can talk to briangt or some one that helped o the apox..
Old 20th July 2003, 10:45 PM   #6
Holger Barske is offline Holger Barske  Germany
Holger Barske's Avatar
http://www.noritake-elec.com/uversion.htm
Add a blue acrylic sheet and it will look like this:
Best regards: Holger
www.holgerbarske.com
Old 29th July 2003, 02:22 AM   #7
the PIC 16F84?
okay i see 2 things that come up, the chip and then there is a programing device that is simplistic and low cost that just plugs into the printer port.
Old 29th July 2003, 10:07 AM   #8
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
Originally posted by Shaun Perez
the PIC 16F84?
thats what you need. you will also need the software for your pc, i would advise the free MPLAB from www.microchip.com also, MPASM to compile the code. a good tutorial for programming is here: www.winpicprog.co.uk and the two documents here (file one) and here (file two) are information about using LCD screens, very useful. they are both PDFs.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 30th July 2003, 02:38 AM   #9
yes, digikey stocks noritake vfd. i think i have enough info to look over thanks. I will try and keep you all up to date! vfd is much better looking than lcd right! I also don't want to spend so much time trying to program my display and then have it look just average, any tips with the noritake would help thanks.
Where to get blue displays???Hide this!Advertise here!
LCD displays moreismore Parts 5 24th February 2006 06:59 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
Copyright ©1999-2017 diyAudio
