| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
They are diodes fashioned into a bridged rectifier.
here's the diagram ("o" represents points where I soldered the leads). o--->|-----o | | o---|<---o | | | o---|<---o | | | o--->|-----o I have the Hammond 369GX and the bridged rectider is for the heater secondary which outputs 6.3VAC 2.5A. Well my mains right now is at 249.xxVAC. So heater secondary is at 7.xxVAC. Well when I measure the VDC on the +/- leads of the bridged rectifier, it gives me 20.xx VDC. Is there something wrong? The diodes I'm using are ultrafast Onsemi rated at 1000V 4amps. Thanks for the replies. jayel |
#2 |
Do you use this schematic?
#3 |
I have a schematic too...
![]() well, both of these schematics show the same... |
#4 |
Well I didn't really see that schematic. I just arrange the diodes in such a way that I can place them on a tag strip.
Is there something wrong with the way I arrange them? I've checked alot of times and I'm prettys sure they still follow a brdige rectifier. Also, i must add that there is nothing else on the circuit aside from the bridge rectifier. Thanks Jayel |
#5 |
Strange problem you have, I can't see why you should get 20V.
what do you use for measuring, scope or meter? Have you grounded - lead of the rectifier? |
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| 4 rfb-02 rectifier bridge pcb's | BeerCan | Swap Meet | 1 | 23rd July 2008 07:07 PM |
| How much AC is usually let through a MUR860 rectifier bridge? | bg4533 | Power Supplies | 9 | 12th April 2005 03:10 AM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Bridge Rectifier | thylantyr | Solid State | 2 | 21st August 2003 09:11 PM |
