Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th December 2010, 12:44 PM   #1
SAC is offline SAC  United Kingdom
Default 2.5mm DC socket 24V 6A capable. Where???
I have two of these smps bricks below, each to power a 41Hz amp9 board. I cannot find a 2.5mm socket for my amp chassis with the necessary voltage and amperage capacity. So many suppliers do not state these values, especially laptop sockets, although I do not want a PCB socket if I can avoid it.
High Power MultiVoltage Universal Laptop Power Supply Free Delivery : Laptop Power Supplies : Maplin
2.5mm DC socket 24V, 6A capable.
An example which does not meet the spec;
http://www.maplin.co.uk/Module.aspx?ModuleNo=1416
I do not want to cut of the lead plug to use XLR sockets for switching reasons with my other amps when the need arises. I am in the UK.
Thanks for any suggestions.
Old 13th December 2010, 08:21 AM   #2
Found a possible answer elsewhere. Here it is for anyone interested.
I just found the Radioshack UK branch. Out of Edinburgh apparently. The socket suggested to me elsewhere, and that I have now purchased is in the US here;
http://www.radioshack.com/product/in...ductId=2102489
In the UK, can be found here;
http://www.radioshackuk.co.uk/epages...ducts/274-1576
Which 24v dc power supply for T amp? dublin78 Power Supplies 1 16th May 2010 08:45 AM
FS: Xfmrs: 6.3VAC @ 6A, 80VAC (CT) @ 6A stoc005 Swap Meet 0 1st January 2010 10:47 PM
3.5mm stereo socket quality difference wiredmonkey Solid State 3 27th August 2009 12:12 AM
lm3875 24v dc at speaker outlets ! ? stobsy Chip Amps 11 8th August 2005 04:52 PM
Reduce 24v DC to 18v DC finestocean Parts 9 29th July 2005 08:46 PM
Page generated in 0.07782 seconds (71.49% PHP - 28.51% MySQL) with 10 queries
