Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
ever make a switch?
ever make a switch?
Old 17th July 2003, 12:08 AM   #1
travis is offline travis
Send a message via AIM to travis
Default ever make a switch?
i need a heavy duty (for footswitch) SPDT momentary switch. i need it to toggle a D flip-flop and i can't figure out how to debounce a clock without two throws.
i figure i can get some pieces of metal and something bouncy/spongy ...
any suggestions?
know of another way to use digital stuff to toggle a relay on and off with one switch? i like the D flipflops because i can use one switch to go to all the different preset inputs to turn everything (two or three channels) on at the same time.
is it a bad idea to power a line-level opamp with the same battery (2x9V, probably) that powers the relay coils?
donuts
Old 17th July 2003, 06:46 AM   #2
psychokids is offline psychokids
Sounds pretty similar to a problem a lot of people have with guitar electonics. The footswitches are all made for switching 120v ac, which can burn through a little crap between the contacts, much unlike the 100 mv guitar signal. So, many times they stop working fairly quickly. To get around this, I use a switch actuator, heres a pic at http://www.smallbearelec.com/Ordering/actuator.jpg . You can buy them at www.smallbearelec.com, and you can put a pcb on standoffs with a momentary switch found at mouser and many other places for 40 cents, and they are good for at least 100k operations. From the momentary switch, its quite simple to make a circuit for whatever you want with logic chips and relays. One similar to the one i use is found at www.geofex.com/FX_images/ltchrly.gif , and its excellent for use with batteries due to the latching relay. I can put my full body weight on the switch and nothing happens due to the shoulder on the actuator. Good luck.
-Chris
Old 22nd July 2003, 04:51 AM   #3
gmphadte is offline gmphadte  India
Hi
There is an IC specifically designed for switch debouncing and needs one capacitor to be connected externally.
It is an Hex Contact Bounce Eliminator from Motorola.
The number is MC 14490
Enjoy
Old 23rd July 2003, 09:34 PM   #4
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Toggle circuit with built in debounce
I've used this circuit for years. It works.
Old 24th July 2003, 08:42 AM   #5
dhaen's Avatar
It has been politely pointed out to me by a fellow member, that this circuit does break one of the design rules:
Generally but not compulsarily, unless specified, the inputs of a digital IC are not connected to timing components (RC). This leads to slow rising/falling waveforms which leads to false triggering. These slow waveforms are handled using schmitt input devices (normally gates are available).
This is true.
When such design rules are broken, one consequence can be that a circuit fails to work under certain circumstances eg temperature, different chip make, different switch type etc.
I did not design this circuit myself, but obtained it so long ago that I cannot remember it's source. I've used it 100's of times, and it has not failed (yet) for me, though by the "rules" one day it will.
If 100% reliability is required, a dedictated de-bounce chip would be desirable.
Thanks for the advice.
Old 24th July 2003, 09:04 AM   #6
StuartH is offline StuartH  South Africa
Hi
I have had similar problems in the past, but while reading the thread, had a thought.
Could one not use a magnetic reed relay? Either as the switch itself, or to trigger an instrumentation grade relay.
The spacing between the reed and magnet would be important, however it would last for ages, and no mechanical parts!
Stuart
Old 25th July 2003, 02:32 AM   #7
i think i will try that circuit. allelectronics has some pretty tough looking SPDT momentary switches.
neither digikey nor mouser have MC 14490s,
donuts
Old 25th July 2003, 03:08 AM   #8
looks good?
donuts
Old 25th July 2003, 09:34 AM   #9
dhaen's Avatar
Originally posted by travis
looks good?
Better but I don't know if it will be tolerated in the feedback from -Q to D.
It'll take no time to try though.
ever make a switch?Hide this!Advertise here!
switch-on, switch-off sequence for preamp/amp cbutterworth Tubes / Valves 1 2nd March 2007 12:41 PM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
Main on/off switch for amp using a piezo switch using_e Solid State 13 20th June 2006 05:55 PM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
