| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Does anyone have experience with analogue switches like SMM2402 and SMM2404 from Analog Device?? Or others??
I intend you use these in my PATHFINDER preamp project (inspired by my now to heavily modified QUAD 34 preamp).
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#2 |
Anyone???
#3 |
Electrons are yellow and more is better!
SSM not SMM
They seems to be alright, quite high performning but I think that analog switches aren't very DIY'ish. If you feel like using them I'm convinced that they will do a good job but the pcb layout may be critical in order to really squeeze otu all possible performance. Careful datasheet and application note reading is recommended. ![]() Not many have used them I gather. It's like asking people about SMD parts like I did before. You must be a pro to know something about SMD.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#4 |
Thaks Peranders,
I know these are used in some studio equipment, and I like the idea of NO mechanical switches or relayes in the circuit path.... I won't call my self a pro in building audio, but I do have worked with and designed many circuits, e.g. 433mHz receivers and transmitters using SMD components... Maybe these switches are to "hardcore" for normal diy's, however I will go for it. Take care,
| Analogue v digital XOs | rick57 | Multi-Way | 25 | 9th May 2007 08:41 PM |
| Class D and analogue | Rivendell61 | Class D | 5 | 23rd June 2006 08:09 AM |
| Different diodes for analogue/digital PS? | float | Digital Source | 0 | 16th May 2005 12:55 PM |
| A simple way to create dual(or more!) rotary switches out of single rotary switches | stappvargen | Pass Labs | 14 | 16th April 2004 11:33 PM |
| fiber vs analogue | shallenn | Digital Source | 5 | 28th February 2003 02:54 AM |
