Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd November 2010, 11:07 AM   #1
bmoraru is offline bmoraru  Romania
Default PCB connectors - how to unplug?
i am working on a Denon DCD-1500AE and wish to take out the audio board that's connected to the transport by several ribbons such as in the attached image - how should i unplug them? first of all, i don't know if the bottom brown connector is soldered to the ribbon cable, or to the pcb? or maybe this is not the detachable end of the ribbon?
Thanks a lot!!!
Old 22nd November 2010, 06:14 PM   #2
DF96 is offline DF96  England
A photo that is in focus would help!
It looks like the bright blue part is attached to the ribbon cable, and the blue-grey part is attached to the board. To separate, just pull steadily with a very slight rocking motion. Do not pull the ribbon, pull the connector. Do not rock too much, as this can bend pins or put a strain on soldered joints. It should get easier as it comes out, so pull less hard. The aim is to get it to come out straight, and under control. Have a look at the pins afterwards, just to check that none of them are bent. A minor bend at this stage can turn into a major bend or a broken pin when you put it back.
When putting it back, try to ensure that the pins line up with the holes. You should be able to feel this. Then push it in. If possible, support the board from behind so you don't flex it too much.
Old 23rd November 2010, 01:06 PM   #3
Default Better photo
This is a more accurate picture of the connector, it’s basically one connector and 1 ribbon cable – would the connector be attached to the cable, or does the cable simply insert into the connector which is connected to the board?
Old 23rd November 2010, 01:55 PM   #4
I'll only guessing but that connector looks like it could be soldered to the PCB.
It (maybe) acts as a converter from stranded to pins.
regards Andrew T.
Old 23rd November 2010, 02:03 PM   #5
theAnonymous1's Avatar
I agree that it looks like they should just pull out of those edge conectors.
Use both hands and grab the thicker bluish part of the ribbon cables and pull up (carefully).
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 23rd November 2010, 03:08 PM   #6
thanks a lot!!
Old 23rd November 2010, 03:22 PM   #7
Banned
It's very hard to tell, even with the better photograph. They seem to be FPC or FFC rather than ribbon cables. They usually just have the copper exposed on one side with maybe a plastic support bonded to the other side and they push into a very tight fitting edge connector socket.
Grasp them as close as possible to the connector with both hands with your thumbs against the connector and your fingers behind and supporting the cable and make a determined effort to separate the cable from the connector by squeezing the cable between your fingers and thumbs and applying a pulling force to it by rolling your fingers and thumbs toward the connector.
This should allow you to apply a measured force to the assembly and hopefully stop short of breaking anything if they are NOT designed to separate. A small amount of differential movement (wiggling) may help.
w
Judging from your post, you've got them out while I was writing
Old 23rd November 2010, 04:00 PM   #8
Thanks for that; I just called them ribbon cables because I had no clue of what they were really called. I've dealt with smaller versions plenty of times but still didn't know what their technical name was.
Old 23rd November 2010, 05:49 PM   #9
indeed they seem to be FFC with a blueish support bonded to the back, and they seem to have no lever that keeps them in place (they seen really thin). gently pulling by the blueish support should work...
How to unplug these connectors? decky Digital Line Level 1 26th October 2008 11:25 PM
PCB to PCB board style connectors rtarbell Parts 8 8th October 2008 10:55 PM
Guide Me PCB Connectors haseeb Parts 1 10th June 2008 08:49 PM
MTA PCB headers/connectors? jarthel Parts 6 5th September 2007 12:34 AM
PCB connectors gretzteam Solid State 6 3rd May 2003 02:01 AM
Page generated in 0.11577 seconds (80.04% PHP - 19.96% MySQL) with 11 queries
