| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Looking for a power switch for a Marantz 2252.Looked on ebay and was wondering if switch from any other model would be compatible.Any parts supplier out there.
#2 |
How about a photo of the old one? I have many power switches, but no idea which ones might have been used in what.
#3 |
Hi here are the photos thank for your help Ivan
#4 |
An AT PC computer switch may work if there is plenty of room around it. The hole spacing on these is about 20mm with an M3 thread and they have a square shaft for the knob (button). Usually the knob can be pulled off to check.
Alps has plenty of switches like that but are only low voltage and amps. Some Japanese manufacturers overcome that by wiring through both poles. Finding a high amp push button switch is not easy and is why I suggested the AT PC computer one which are rated at 5A-10A.
No longer DIY active |
#5 |
Thaks for your help rabbitz will look at that option
#6 |
Yeah, I have one similar, 20mm spacing. If you dropped by a local computer repair shop, you could probably look at the switches used to see if one yould fit in your unit.
#7 |
Order one from the internet fits perfectly model KDC-A04 power switch stereo works great fits perfectly even screw holes line up perfect,thank Ivan
#8 |
I attached photo of replacement switch KDC A04
| Marantz 1060 power switch | Tut | Parts | 12 | 21st October 2010 09:59 AM |
| Capacitor Across Power Switch to Control Switch On Noise? | DreadPirate | Analog Line Level | 17 | 1st March 2010 03:47 AM |
| Marantz 9 output power switch | Tubesin | Tubes / Valves | 3 | 20th December 2008 02:08 AM |
| Marantz 2245 replaceing power switch - need help | Johnduaneg | Solid State | 4 | 1st June 2008 09:56 AM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 08:23 PM |
| Page generated in 0.07753 seconds (78.55% PHP - 21.45% MySQL) with 11 queries |
