| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#51 |
Hi Viki, thanks! But I do not deserve so much praise as
I did not write that database. Actually found it on the net while searching and put it here for people..... It was very helpful. I purchased a 12v motor from servo electronics listed there for making a DIY PCB drill, they have materials for making such a drill.... Looking forward to you additions.... Roushon
S. Roushon |
#52 | |
I did call them. They have something called `silver paste with solder content'. I tried to google, it seems this comes in a syringe and for fine solder. Does anyone know how to use it? Thanks Roushon
S. Roushon |
#53 |
it is used for soldering smd chips with very close pins such as tas 5630, it is good dont know cost details. did you get any rates.
#54 |
Will standard soldering iron work? For rate I have to visit them.
Thanks Roushon
S. Roushon |
#55 |
yes Standard will work Just change the tips as needed for component, Mostly people use blower for this,
If you have efy magazine. there were few ads for the same. I have many magazines will have to go through them. |
#56 |
Thanks Viki for the information. In fact I need to solder some SMD. I went to
the Lamington Road today, but shops were closed. Toady got the address of the chromo paper dealer (attached is the scan). He will send paper by post also. The rate is 500pieces A4 size Rs 220/- +shipping. But I think it is best to purchase in person. The paper I have is quite thin and that helps a lot. Roushon.
S. Roushon |
#57 |
Guys I am Selling some of my unused stuff . Check the link.
Disposing unused MJL21193-94 and many more |
#58 |
Does any one know where to buy good aluminum chassis in Mumbai for diy amp.Other wise i was thinking of getting aluminum panels cut according to size from whole sheet.
Also good quality toroidal transformer, if any one has got it made , pls tell the rates you got it made. |
#59 |
Guys There is one shop SB electronics at lamington rd , He some times has good quality drivers .Last time i saw 8" sharp polypropylene drivers.looked good but without t/s specs.
As you take left from under the tunnel below flyover. The shop is just at the opposite corner of 1st right. i want to purchase smd components does any one know any good shop. |
#60 | |
cut suitably. It is a difficult job. I got three toroidals made. 230v primary, 0-33v, 0-33v 5Amp per rail sec. (2pieces Rs 4718/- (incl Tax), 2006 from radio electric, the address in this thread) 230v primary, 15-0-15v, 15-0-15v 2Amp per rail sec. ( one piece Rs 900/- (incl Tax), 2009 from Chandratronics again address in this thread). The addresses are in post 3. Both are very good. Roushon
S. Roushon Last edited by Roushon; 27th January 2011 at 11:43 AM. |
| Parts availability in India | ashok | Parts | 1 | 8th June 2011 05:49 PM |
| [INDIA] Any DIYer made a Gainclone in India. willing to help? | smarcher | Chip Amps | 62 | 2nd April 2009 05:05 AM |
| I am from Mumbai, India. | rakeshln | Introductions | 2 | 10th June 2004 03:39 PM |
| DIY Audio parts sourcing for Live Sound Reinforcement in India | peterpan73 | Parts | 0 | 19th February 2004 11:28 AM |
