Parts in Mumbai (India) - Page 56 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st May 2013, 07:02 AM   #551
Originally Posted by Roushon View Post
Looking for good FM antenna. Did some study on the net
about different types.
1. Yagi
2. J-pole
3. Multi-directional (round dipole)
4. Square shape (using simple wire)
5. Using flat 300Ohm cable
Does anyone know where I can get a ready made good antenna in Mumbai? I know it is a very classical/obsolate subject. I live in Colaba, so do not need a high gain one. Space outside flat is a problem, so need a small outdoor type. At present made a type
4 and is not up to the mark I want. Thinking of making one but not have much time.
Roushon
Roushan,
may be i am replying late , but try antenna mangoos software even free ware will do job for you. you can design many antenna your self . i made 865mhs uhf rfid antenna for my self and i cant tell im 90% success full in my first attempt
Old 1st May 2013, 07:15 AM   #552
Roushon is offline Roushon  India
Originally Posted by m1mahesh View Post
Roushan,
Thanks Mahesh! I did make a J-pole antenna sometime back and it is working well. Someone from Pune in the hifivision forum suggested and I found the design online.
It was fun doing it...
Roushon.
S. Roushon
Old 2nd May 2013, 04:03 AM   #553
but try antenna mangoos software even freeware will do job for you.
Can you pls share the download link.
There is always a first time....
Old 3rd May 2013, 05:14 AM   #554
Default Lubricant!
Urgently need very good quality dry lubricant to grease
the laser assembly of the cd player. Found out one of the
following is needed: 1. Molylube dry lubricant, 2. Krytox
glp-204 or 3. Silicon grease. Not sure which one is best
(may be all are same, I do not know) and where do I find
it in Mumbai. Any suggestion?
Every incidence is a learning experience!
Thanks and regards
Roushon.
S. Roushon
Old 3rd May 2013, 06:10 AM   #555
availlyrics's Avatar
I'm not sure about the quality part, I bought it from Lamington street(called White grease) for Rs15 from Suman 02223864117(stall nr Skyking). Works well for my DVDRW.
Thanks,
availlyrics
Old 3rd May 2013, 06:20 AM   #556
Great! Thanks a lot for the information.
Roushon.
S. Roushon
Old 4th May 2013, 05:41 PM   #557
Default Silicon grease!
Found out, `white grease' is for heat sink. `Silicon grease' is different and is a lubricant, available in `Anupam Tools' exactly opposite the Police station on the Lamington Road. Sorry, do not have their phone number.
Anyway, thanks for the hint!
Roushon
S. Roushon
Old 6th May 2013, 04:59 AM   #558
Sorry, I might have mixed up the names
Thanks,
availlyrics
Old 9th May 2013, 06:39 AM   #559
You better not use silicon grease. It is originally intended for use on O'rings in water tight containers.
I am very much sure of one thing...the local made Si grease will harden over time and u will have problems. Product from Dow Corning is good... don't know if it is still available or available locally.
Gajanan Phadte
Old 9th May 2013, 12:58 PM   #560
ashok's Avatar
As used for heat sinks , silicon grease is mixed with a white metal oxide filler. The one for lubrication generally is transparent.
The white silicone grease does dry out over time but that is in years and not months. If you do pull out anything after a long time which has grease under it you will have to reapply fresh grease while putting it back. Make sure you clean off the old grease before applying fresh grease.
AM
[INDIA] Any DIYer made a Gainclone in India. willing to help? smarcher Chip Amps 63 2nd January 2014 12:07 PM
Parts availability in India ashok Parts 1 8th June 2011 06:49 PM
I am from Mumbai, India. rakeshln Introductions 2 10th June 2004 04:39 PM
DIY Audio parts sourcing for Live Sound Reinforcement in India peterpan73 Parts 0 19th February 2004 12:28 PM
Copyright 1999-2017 diyAudio
