Parts in Mumbai (India) - Page 55 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th April 2013, 08:41 PM   #541
Originally Posted by ashok View Post
SPDIF is 75 ohms terminated. Everything in the chain from the chip output to the reciever input must have a characteristic impedance of 75 ohms. EVEN the connectors. IF this does not happen you get reflections. If your system can tolerate ordinary RCA sockets and plugs and you cannot hear any problems due to jitter in your system then you can just stick to that . There is always an ideal goal. But you can often get away with imperfections in your system. If your ear is happy , that's all that matters.
I tried to write a longer explanation on this but it took too much time just to get part way. So I googled and found a write up by Steve Nugent which explains it very well. Read it.
spdif
Cheers.
good artical Thanks ashok
There is always a first time....
Old 17th April 2013, 02:09 PM   #542
Send a message via Yahoo to linuxguru
Originally Posted by Roushon View Post
Will search for Rubycon ZL or ZLH as you say. Could you tell me where can I find them (physical shop) genuine in India?
Arihant (just off S.P.Road in Bangalore) had 1000uF/35V ZL and 1000uF/25V ZLH a while ago, and may still have stock. He sources from importers in Mumbai, so somebody there has stock of genuine Rubycon from time to time, but may not be willing to sell in retail quantities - look around and search a bit.
Another inexpensive alternative with magnetic leads which is as good or better than Panasonic FM is Nichicon or Taicon HD. Also look for Panasonic FJ, Nippon Chemicon KY and KZE. All of these were used in large quantities in PC motherboards, so surplus quantities must be around.
Old 17th April 2013, 02:26 PM   #543
ashok's Avatar
Rubycon India Liaison Office.
Kandivali East, Mumbai. ph: 022-28543154, mob: 09820408945
Maybe be able to put you on to someone who can supply off the shelf in Mumbai.
AM
Old 18th April 2013, 04:54 AM   #544
Roushon is offline Roushon  India
Great! Thanks a lot Linuxguru and Ashok. I will pursue your suggestion and if find in Mumbai, will post the details of the
retailers here.
Roushon.
S. Roushon
Old 25th April 2013, 06:36 AM   #545
Default Ebay site: free shipping to India!
In case it interests to any of you, I came across an ebay
site which ships free to India and has a huge store for
ICs. One example
10pcs IC LM3886TF Amp Audio PWR 68W AB TO220 11 New Good Quality Tracking Number | eBay
Roushon.
S. Roushon
Old 26th April 2013, 11:00 AM   #546
This may be disappointing...
ICCWORLD has stopped purchasing items on your behalf.
I was badly in need of import of a driver and this was informed to me for my purchase inquiry.
Gajanan Phadte
Old 26th April 2013, 11:16 AM   #547
Gajanan Phadte
There is a better way. Register for PPOBOX here.
ICC World
It is pretty good. I purchased through this method.
But couple of points to remember: 1. Ask the seller in US/UK to make packet size small. 2. Also tell them the packet will be further shipped to India and hence not to
make it unnecessarily heavy by adding stocklists etc. ICCWORLD decides on the shipping by some formula called volumetric, so it depends on volume as well as weight. For example if the volume of the packet is
N cubic cm then the volumetric is N/5000kg. The shipping charge will be calculated based on whichever is higher: N/5000kg or the actual weight. You can also call them for some more clarification.
Once they charged me more shipping and then after some amount of digging I found out the above secret and they had to refund me some money.
All the best
Roushon
S. Roushon
Old 29th April 2013, 10:40 AM   #548
We stock audio diy parts like Genuine Panasonic, Nichicon, Nippon chemi-con capacitors, Metal film resistors, Power resistors,Heat Sinks ( various profiles ), Toroid transformers, National Semiconductor IC, OPA opamps etc in India. All components are genuine and new ( not NOS ).
please visit diy audio india -Buy Film capacitors, Panasonic capacitor, Nichicon capacitor, Toroid transformers, Heat Sinks, Oxygen Free wires online at diycomponents.in
Old 30th April 2013, 07:03 AM   #549
Default Thanks!
Thanks for your posting. Wandering if you have parts of
other values except for those in your web page. I find the
list a bit limited...
Roushon.
S. Roushon
Old 30th April 2013, 07:10 AM   #550
Roushon.
We are still updating the parts list on the site, some more components should get added by this week. If you have any specific requirement please PM me.
[INDIA] Any DIYer made a Gainclone in India. willing to help? smarcher Chip Amps 63 2nd January 2014 12:07 PM
Parts availability in India ashok Parts 1 8th June 2011 06:49 PM
I am from Mumbai, India. rakeshln Introductions 2 10th June 2004 04:39 PM
DIY Audio parts sourcing for Live Sound Reinforcement in India peterpan73 Parts 0 19th February 2004 12:28 PM
Copyright 1999-2017 diyAudio
