Parts in Mumbai (India) - Page 53 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th April 2013, 05:15 AM   #521
ashok's Avatar
Originally Posted by vkj View Post
Another audio question: Is it possible to send digital audio (from say a DVD player) over long distances (~20 feet) via 75 Ohm cable and do the D-A conversion at the far end?
vkj
Use BNC connectors and genuine 75 ohm video cable. I think Neutrik has 75 ohm RCA type connectors but would be quite expensive and harder to find.
Regular RCA connectors are not 75 ohm and you could have quite a bit of loss there. Safest is to stick to BNC as you get good quality BNC connectors in the market.
You can find that many audiophiles have pulled out the RCA SPDIF output connectors on their players and replaced them with BNC sockets and usually not just because they want to take the signals over longer distances.
AM
Old 8th April 2013, 07:13 AM   #522
gannaji is offline gannaji  India
I am a regular reader of this thread. Glad to note that DIY activity is very live in india.
Can I request that when a source for an item is mentioned, the contact details may also be given like t el no and url if exists. This will help non bombayites also to contact the parties.
Gannaji
www.samritatrust.org
Teach me the glorious lesson that occasionally, I might be mistaken. Keep me reasonably sweet.
Old 9th April 2013, 03:43 AM   #523
vkj is offline vkj  India
Originally Posted by linuxguru View Post
Liquid flux is a recent innovation, and generally meant for wave-soldering or hand soldering on plated surfaces in current use - Sn/Pb, lead-free, immersion silver or gold. It works great on clean uncontaminated surfaces, and produces shiny, concave solder beads. It's really mainly meant for solders to flow very smoothly and wet surfaces.
For terribly contaminated copper surfaces (with lots of oxide and other metallic impurities like aluminium, iron, etc.), ammonium chloride aka Sal Ammoniac was the only easily available flux that worked in the old days. It's a white slightly hygroscopic salt that used to be available from chemistry supply stores. It's harmless and non-toxic in solid form, but produces an acrid cloud of ammonia and hydrogen chloride at the moment of soldering. I don't know if Mangaldeep's aluminium flux is the same thing, but sal ammoniac works with some difficulty on aluminium surfaces also.
The spectacled guy in the same row of shops as Mangaldeep (the enamelled Cu wire store) is the Watts dealer and specializes in resistors. You can ask specifically for Watts and maybe a few other local brands from him. Most other shops will also give you Watts on request, but they source it mostly from the spectacled guy above. It's clearly marked on the paper tape, so there's no hanky-panky. The leads will be very soft tin-plated pure copper on almost any Watts resistor, except on some older stuff where they used tin-plated brass.
The problem with the cheap resistors is ferromagnetic leads or end-caps. The worst are those Fe-Cu (Fecuma) leads seen on cheap metal-oxide resistors, but nickel/kovar plating is also weakly magnetic and messes up audio.
Weakly magnetic end-caps now seem to be an unavoidable evil, even on otherwise high-quality imports like Panasonic ERX metal film and KOA CF carbon film. There are very few resistors now that are completely non-magnetic - Dale, PRP, Futaba, NOS Holco, Welwyn and some Shallcross non-inductive wirewounds come to mind. Of these, Dales are the only ones that occasionally show up locally.
I have one of those Rs.100 Chinese MP3 modules with remote as well.
I haven't tried it yet, just wanted the little IR remote actually.
For high-quality digital playback, the best options are moderately expensive: A linux-based Atom motherboard connected to a separate USB 2.0 audio DAC like the HiFiMeDIY Sabre ES9023 24/96 DAC.
Sure, you just need a DVD player with digital SPDIF coax output, and a DAC or an amplifier with SPDIF digital input. Many DVD players have SPDIF built-in, and some have optical output as well.
There are inexpensive modules that can convert the optical signal back to coax SPDIF digital, or slightly more expensive modules that have a DAC and can convert optical to 2-channel line-level analog audio.
The simplest option is any cheap Home Theatre receiver that has digital input - just about any Sony, Pioneer, Kenwood, Panasonic, Harman-Kardon, etc.
Thanks for the info, Linuxguru. I was under the impression that Amm. Cl. was a no-no for electronics. I remember in the old days when brass vessels were coated with lead and this was liberally used by the fella with that most interesting bellows who used to set up a furnace right on the road side! Eating all that lead has given me a very good excuse for my insanity tho .
The Al. flux is prob. Amm. based, its liquid tho and is quite corrosive. For ~Rs 200 I sure hope it isnt just Amm. Cl.
Its really quite incredible that this Chinese manuf. can produce a MP3 board PLUS a remote for peanuts, literally. It just doesnt make sense. I was so excited that I bought two . Unlike that pathetic Sony 660P DVD player, it handles NTFS flash-drives too! If it wasnt for that popping noise, it would be quite decent, actually.
If I recall some of the Microchip processors have a built-in USB support. Not sure if they have the HP to do the MP3 tho. The Microchip website has a section on MP3 apps. but it appears to be mostly for low-quality voice.
I have a stand-alone DAC, a small, but expensive unit made by Audio Alchemy. Tho it claims to be a audiophile type, with those thick gold plated Monster Cable audio outs, I was a bit surprised to find a very ordinary Cirrus Logic run-of-the-mill DAC chip (forgot the no.). I was hoping to press this into service for the remote amp.
I dont have an AV recr. I made a 5-ch PA (Leach) and bought a Proton Preamp way back (the co. is out of business now, and with good reason--another ripoff). The latter has developed an intermittent distortion on the center channel, and I am unable to fix it.
vkj
Old 9th April 2013, 03:56 AM   #524
Thanks. Can you explain why BNC is required? AKAIK, unlike in (analog) video, the SPDIF signal isnt 75-ohm terminated? I would imagine that one uses the coax simply to minimize cap. loading. Im guessing the difference between a cheap coax and good coax cable in terms of cap. isnt that much? I would certainly agree for 75 Ohm applications, resistive loading would contribute to reflections, and hence here a good coax is important. Right? or am I missing something?
vkj
Old 9th April 2013, 05:12 AM   #525
availlyrics's Avatar
Originally Posted by gannaji View Post
......Can I request that when a source for an item is mentioned, the contact details may also be given like t el no and url if exists. This will help non bombayites also to contact the parties.
Gannaji
https://docs.google.com/spreadsheet/...ueTF1X3c#gid=0
by Roushan
Thanks,
availlyrics
Old 9th April 2013, 05:21 AM   #526
Roushon is offline Roushon  India
Gannaji
This was the main purpose of this thread and it is systematically maintained. Please check back postings, wherever source of parts are given, all details are mentioned. I am grateful to all the contributors. A page was also created by Aucosticraft.
You can also contribute to this page by clicking the below link.
https://docs.google.com/spreadsheet/...QUpueTF1X3c6MQ
Edit: The above page does not yet contain all the informations posted in this thread.
Roushon.
S. Roushon
Old 9th April 2013, 04:18 PM   #527
Thank you , dear Roushon!
--gannaji
Old 10th April 2013, 02:10 AM   #528
Default A request!
I was just reading some few back pages and was happy that people also discuss about parts and their availability. But noticed these discussions are pointed towards persons who are aware of the local market and names of the retailers.
My request to all the posters that whenever you mention the name of a particular retailer please give full details, like full name, full address and phone numbers and then you can continue your discussions.
In case you are only interested in discussion then please open a new thread with the correct thread name, that will give more exposer to your subject and at the same time protect the purpose of this thread.
Thanks and regards
Roushon.
S. Roushon
Old 10th April 2013, 07:46 AM   #529
Default Soldering Station
where can I find a good soldering station in Mumbai.
Old 11th April 2013, 07:06 AM   #530
Lamington Road, there are many shops near police station.
Gajanan Phadte
[INDIA] Any DIYer made a Gainclone in India. willing to help? smarcher Chip Amps 63 2nd January 2014 12:07 PM
Parts availability in India ashok Parts 1 8th June 2011 06:49 PM
I am from Mumbai, India. rakeshln Introductions 2 10th June 2004 04:39 PM
DIY Audio parts sourcing for Live Sound Reinforcement in India peterpan73 Parts 0 19th February 2004 12:28 PM
Copyright 1999-2017 diyAudio
