| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#401 |
So Roushan , you got a luck. And thanks for updating the store information on the sheet. A request , when ever we update the store information pl. put a one line at the end of post, that the details are updated on the sheet. that will help to remind others here, that when ever new store is discussed it should be updated. Thanks once again, for being particular.
There is always a first time.... |
#402 |
Does anyone know where you get 100pF dipped mica caps ( 500V) in Mumbai or Bangalore ? Any idea what they cost ?
AM |
#403 |
Narain electrical is/was somewhere below visha/gala IIRC.
Gajanan Phadte |
#404 |
Mahesh,
Thanks, I have received all the parts. Gajanan Phadte |
#405 |
Looking for good FM antenna. Did some study on the net
about different types. 1. Yagi 2. J-pole 3. Multi-directional (round dipole) 4. Square shape (using simple wire) 5. Using flat 300Ohm cable Does anyone know where I can get a ready made good antenna in Mumbai? I know it is a very classical/obsolate subject. I live in Colaba, so do not need a high gain one. Space outside flat is a problem, so need a small outdoor type. At present made a type 4 and is not up to the mark I want. Thinking of making one but not have much time. Thanks Roushon
S. Roushon Last edited by Roushon; 26th December 2012 at 06:01 AM. |
#406 |
S. Roushon |
#407 | |
The size is small something like 30cm x 2 cm.
There is always a first time.... Last edited by Aucosticraft; 27th December 2012 at 04:36 AM. Reason: too add |
#408 | |
However, if you want a few 100pF/50V/5% dipped SM (probably Saha or CDE, I forgot which one) and can pick them up at B'lore or Chennai, PM/email me. You can check at Majestic in Chennai for SM, but I seem to remember that he no longer has any stock. |
#409 | |
Thank you. Regards Roushon
S. Roushon |
#410 |
Silver mica will add a metallic glitter (somebody worded it here very nicely)to the audio if used anywhere in audio. Even if u use a 1nf across the supplies, u can hear its adverse effect. The natural softness of sound goes away.
I had this effect on my amp and I was not understanding what was happening. As soon as I read about it, I removed all the SMs. Gajanan Phadte |
| Parts availability in India | ashok | Parts | 1 | 8th June 2011 05:49 PM |
| [INDIA] Any DIYer made a Gainclone in India. willing to help? | smarcher | Chip Amps | 62 | 2nd April 2009 05:05 AM |
| I am from Mumbai, India. | rakeshln | Introductions | 2 | 10th June 2004 03:39 PM |
| DIY Audio parts sourcing for Live Sound Reinforcement in India | peterpan73 | Parts | 0 | 19th February 2004 11:28 AM |
