Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Parts in Mumbai (India)
Old 28th August 2013, 01:01 PM   #781
Roushon is offline Roushon  India
Originally Posted by mark28new View Post
Press-n-Peel Blue is expensive $2 per sheet
And Rs 70/- per dollar!
Roushon.
S. Roushon
Old 29th August 2013, 05:53 AM   #782
masood is offline masood  India
DEAR SIR
I WANT A ECONOMIC FINE PCB BOARD(COPPER CLAD) CUTTER AND 60 A AMPERE METER
Old 29th August 2013, 06:14 AM   #783
Originally Posted by masood View Post
DEAR SIR
I use acrylic cutter for this purpose. See the attached picture. Go to any hardware store and ask for `acrylic cutter', it costs around Rs 50/-, purchased long back, may be more now.
Such Ampere meter is available in big electrical goods shop.
Edit: You have to slide the cutter softly on both sides of the board and when it is weak enough, break it. It needs practice.
Edit: Or you can use plane saw blade used to cut iron rod etc.
Roushon
S. Roushon
Old 29th August 2013, 06:18 AM   #784
m1mahesh is offline m1mahesh  India
DEAR SIR
http://i42.tinypic.com/og9bw4.jpg
i am using this, order from ebay(was not available in local hardware store) around 2.28 USD, quality inst that good better to say poor , blade run-out after 3-4 cuts. look for same kind of thing.
Old 29th August 2013, 12:48 PM   #785
mark28new is offline mark28new
where can I buy a Cheap laminator for PCB toner transfer
Old 1st September 2013, 08:35 AM   #786
Originally Posted by Roushon View Post
Here is the details of the shop I mentioned before. Drill bits of all sizes, hot air guns (Rs 350/-), MX crimper (Rs 300/-) and all kinds of tools. (Crowded and tiny shop.) Drill bits Rs 5/- a pieces (0.8mm, 1m I purchased).
Roushon.
Hi Roushan,
yesterday visited this shop and i purchased 5 types of drill bits in qty of 10 at 5 rs each. i have not tested quality of drill bits but looks good, earlier i used to purchase from LR and item cost was 15-25 rs each. you saved my lot of money. now i have vial full of drill bits.
i also brought acrylic cutter only at 60 rs and 4 additional blade 10 rs each blade, quality good.
thanks to only you
Old 2nd September 2013, 04:23 AM   #787
Originally Posted by m1mahesh View Post
Hi Roushan,
thanks to only you
You are most welcome! I am very happy that my effort is helping hobbyists.
Roushon.
S. Roushon
Old 2nd September 2013, 06:02 AM   #788
me too looking for Cheap Laminator
Old 2nd September 2013, 06:05 AM   #789
You were in Lohar chawal yesterday did you check for Lamination machine in Abdul Rehman Street. I believe that chromo paper + lamination machine + TRF should produce pcb with very fine track.
May I ask why do you require so many drill bits. Do you have a work shop.
Old 2nd September 2013, 07:31 AM   #790
i was not aware Lamination machin will available at Lohar Chawl, next time i will defiantly check at location suggested by you.
i live in Uran which almost two and half hours to Mumbai and my office hours dont allow me to spend time on other things . so usually i buy in quantities so it can run for 2-3 months easily .
Parts in Mumbai (India)Hide this!Advertise here!
[INDIA] Any DIYer made a Gainclone in India. willing to help? smarcher Chip Amps 63 2nd January 2014 11:07 AM
Parts availability in India ashok Parts 1 8th June 2011 05:49 PM
I am from Mumbai, India. rakeshln Introductions 2 10th June 2004 03:39 PM
DIY Audio parts sourcing for Live Sound Reinforcement in India peterpan73 Parts 0 19th February 2004 11:28 AM
Copyright ©1999-2017 diyAudio
