Pio russian capacitor K42-11...is good ? - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th November 2010, 09:55 AM   #31
Hello
Actually I'd like hard sound if is hard on the bass and precise. Also if is fat sound not thin! Like some silver wire make the sound thin..
I have at hand some Russian Teflon capacitor I will test them.
Everybody since to have diferent opinion.
I want to use them in a simple circuit mosfe amplifier.
These is the Zenotron. JFet in and lateral outputs, Simple circuit. For that reason is important to chose the best cap (or which one the best in that circuit)
The amp works in Class A, tested and sound good but very sensitive to every pats used in the circuit!
I run these amp more than 3 weeks now.
I only use foil caps , I tried Elna Silmic but not my taste at all! At least not in these amp!
A simple PIO better here than the Silmic!
Greetings
Old 18th November 2010, 10:04 AM   #32
Professor's Avatar
Originally Posted by Wavebourn View Post
Audiophooles believe, they have hard sound: as hard as mica itself.
Teflon in oil has smooth and silky sound.
Maybe )
Russian PIO caps. Should I use them? G Parts 118 23rd October 2016 10:02 AM
K40 or K42 Russian PIO: what would you use/recommend? jarthel Tubes / Valves 4 5th December 2011 02:21 PM
2.2Uf PIO Russian capacitors gaborbela Swap Meet 1 5th January 2009 03:54 AM
Cheap Russian 2.2uF 400V PIO Capacitor mus Parts 13 18th July 2006 12:56 PM
looking for 1uF at least 200V Russian PIO jarthel Swap Meet 2 10th June 2006 08:23 PM
Copyright 1999-2017 diyAudio
