Pio russian capacitor K42-11...is good ? - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th October 2010, 06:05 PM   #21
M Gregg is offline M Gregg  England
Originally Posted by piano3 View Post
Surely PCB's were mainly used in capacitors utilised in power generation- not in the kind of ones we all use?
Motor run, fluorescent gear, HV caps "small and large", army surplus, transmitters, some radio gear, etc etc.
M. Gregg
Old 7th November 2010, 05:51 AM   #22
regal is offline regal  United States
I have an SET hybrid tube headphone amp. Think of it as a parafeed with the OPT being a very transperant SS buffer.
Well with this amp the coupling cap between the tube and the buffer is the bottneck of the amp (. I compared several caps.)
The russian KY40's I think are over-rated. I found the Jensen and AmpOhm copper PIO caps to be much more transperant, in fact the KY40 seemed to change the sound signature like a lens.
Old 17th November 2010, 04:37 PM   #23
Default The differences between these two PIO caps
Hello
I would like to ask for some help
What is the difference between these two Russian capacitor , I think other than the higher voltage.
You can see one marked (was produced?) CCCP and after the usual mark K40Y-9 there is a number 3.
Another does not have.
Also one 10% another 20% tolerance.
Which would be better sound wise. Any advice or experience ,please help I need to buy some of these PIO caps.
The size and voltage not a problem! The circuit let me to use even 100V or less.
Also I read the K75-10 is a great capacitor. Do these sound better than the K40Y-9 type.
Also do these capacitors has signal in/out??
Thank you for your help.
Greetings
Old 17th November 2010, 05:02 PM   #24
Professor's Avatar
Originally Posted by gaborbela View Post
Hello
Greetings
The left: 0.22 uF 1000 V, right: 0.22 uF 200 V
Old 17th November 2010, 05:31 PM   #25
Hello
Other difference than the voltage!
One is look like made a couple years back made in CCCR , another probably newer.
Also the 10%-20% differences.
But I would be more interested to know which one is better sound wise?
Also the K75-10 is as good than the K40-9Y or may be better?
The problem if I buy these caps I have to buy min 8PC or so .To buy from all to know which one is better a bit waste of money. Plus shipping is not cheap to Canada.
Greetings gabor
Old 18th November 2010, 12:29 AM   #26
piano3 is offline piano3  United Kingdom
You can see the date codes on the bottom of the picture-the one on the right is the older one. I would not expect a significant difference in sound and if you are short on space then the 200V should be fine as the voltage rating on these caps is usually very conservative. K75-10 is normally used by diy'ers in power supplies(although I am pretty sure they were intended for something fairly exotic originally) and they are really quite big.
Old 18th November 2010, 03:43 AM   #27
tympani1d's Avatar
Originally Posted by Wavebourn View Post
Here you go: translated Russian table about digits and designations.
Google Translate
Wavebourn: As always, Thank you for the info.
I think; therefore will NOT be Politically Correct.
Old 18th November 2010, 05:20 AM   #28
Professor's Avatar
Hello
Greetings gabor
I dont know about sound K40 but i know in Russia best SSG-2, SSG-3 (ССГ-2, ССГ-3)
Old 18th November 2010, 05:43 AM   #29
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Audiophooles believe, they have hard sound: as hard as mica itself.
Teflon in oil has smooth and silky sound.
The Devil is not so terrible as his math model is!
Old 18th November 2010, 07:40 AM   #30
K40U9 excellent decoupling capacitor, very hard to find 400V version nowadays. I got 10 pieces at Unona flee market last Spring and the guy told there would be no more.
I would say K40U9 is the best Russian capacitor sonically, excellent price/performance ratio as well.
imho Duelund Coherent Audio is the best, Mundorf silver-oil is good and not too pricey.
Russian PIO caps. Should I use them? G Parts 118 23rd October 2016 09:02 AM
K40 or K42 Russian PIO: what would you use/recommend? jarthel Tubes / Valves 4 5th December 2011 01:21 PM
2.2Uf PIO Russian capacitors gaborbela Swap Meet 1 5th January 2009 02:54 AM
Cheap Russian 2.2uF 400V PIO Capacitor mus Parts 13 18th July 2006 11:56 AM
looking for 1uF at least 200V Russian PIO jarthel Swap Meet 2 10th June 2006 07:23 PM
Copyright 1999-2017 diyAudio
