Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
How do I easily removed components in a double-sided PCB?
Old 11th July 2003, 12:41 PM   #1
jarthel is offline jarthel  Australia
Default How do I easily removed components in a double-sided PCB?
Well I'm trying to replace the diodes "1N4007" with some ultrafast Onsemis. Well the problem is that the diodes are soldered on both sides and is very hard to remove.
Any ideas on how do it easily?
Thank you.
jayel
Old 11th July 2003, 01:48 PM   #2
nobody special is offline nobody special  United States
nobody special's Avatar
Cut the diode off, leaving a little bit of lead. Heat the remaining lead, using some new solder. When the lead is good and hot and starts to move around (indicating the solder on both sides is melted) gently smack the board on a table top / bench top. The lead should fly right out.
So, the board is double sided, but not plated through? That is odd. If it is plated through, you should only have to heat one side. I use a dental pick to gently pry on the component while heating the lead. The lead will pop off the board when it is hot enough. The easiest way is to just clip the component off and remove the piece of component lead.
Steve
Old 11th July 2003, 03:34 PM   #3
very nice suggestion. I'll do it tomorrow.
Thank you.
jayel
Old 11th July 2003, 03:40 PM   #4
Jocko Homo is offline Jocko Homo  United States
Banned
Do they sell "Solder Wick" over there??
Jocko
Old 11th July 2003, 03:55 PM   #5
I did try to use a solder wick but the solder won't attach or if it does attach, there's still residue and it's enough to still make it hard to remove the parts.
When use the wick, I placed it between the solder and the iron. Is this the right way?
Thank you
jayel
Old 11th July 2003, 04:25 PM   #6
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
If it's OK to ruin the part you want to remove I think nobody special's solution is the best. I practice it often at work. After removal I suck the hole clean with a desoldering station. It's hard to suck the hole totally clean and not damage the hole plating, therefore it's often better to warm the solder joint and then suck it clean.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 14 pcb's in interest so far.
Old 11th July 2003, 06:44 PM   #7
jackinnj is offline jackinnj  United States
jackinnj's Avatar
One of the most frequent problems you find in repairing stuff is blown diodes and resistors -- I just cut the device in half with a pair of diaganol wire snippers -- clean it up a bit and attach the new part to the old leads --
Old 11th July 2003, 08:13 PM   #8
Jocko
Solder wick sucks. Especially in this application. About the only good use for it is cleaning up the board after a component is removed. Even then, I never use it.
But that's only my opinion, of course.
Steve
Old 11th July 2003, 08:15 PM   #9
Two words: "dental pick"
Seriously- a good way to open up holes carefully without damaging pads/traces. Heat the joint up and push it through carefully, twist back and forth as solder cools. Works every time! Faster than a solder sucker, and you don't have to clean it out.
Steve
Old 11th July 2003, 11:42 PM   #10
jackinnj's Avatar
Default "spitz or swallows"
Solder wick sucks.
Isn't that what it's supposed to do?
-- you can get solderwick in all sorts of deniers btw.
How do I easily removed components in a double-sided PCB?Hide this!Advertise here!
double-sided pcb: how to easily remove a soldered component? jarthel Parts 30 29th September 2006 10:51 PM
DIY double sided PCB making sss Parts 2 10th June 2006 07:16 PM
homemade double-sided PCB cb951303 Parts 22 4th April 2006 11:57 PM
Double Sided PCBoards cm961 Parts 3 21st November 2003 04:45 PM
Double Sided PCB Req in the UK Rarkov Everything Else 0 10th March 2003 03:25 PM
Copyright ©1999-2017 diyAudio
