| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Im not sure if this is the right place to post but here it goes...
I have a 1999 US Amps USA-400. Two resistors are blown. I think they are carbon compositions, but im not sure. Im pretty sure the blown ones are the same as the two peach colored ones in the second pic. My question is what do I need to replace these with? And also do I need to replace the other two also? Sorry for the poor picture quality. If it will help I can try to find a better camera. |
#2 |
Those appear to be carbon film, not composition. Looks like at least 1 watt, if not two. I can't clearly make out the color bands; guessing at 21 ohms.
Metal oxide resistors at 2 watts would seem like a suitable replacement. The unburnt ones should be fine. Resistors don't fail by themselves; they're a symptom of failures elsewhere. |
#3 |
Any idea on what caused this to happen? Im pretty sure one of them has been blown since I bought the amp 5yrs ago. The other one just recently went up.
#5 |
I have a few of those amps. I havent run into the problem personally, but could you let me know what impedance you were running and for what duration? Did you find that the amp was running hot ever?
#6 |
I have done some research and discovered those are bias resistors. Should i use cf or mf resistors?
| Dc offset on usamps axtu 1000 | tomat | Car Audio | 9 | 22nd February 2011 11:14 PM |
| FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers | chris-man | Swap Meet | 1 | 28th May 2009 11:47 AM |
| USAMPS USA 100 Terminal Block Mounts | chemhaz | Car Audio | 1 | 26th February 2009 05:03 AM |
| Usamps Vacuum Tube Current Sync Drive | lumanauw | Car Audio | 0 | 20th August 2008 02:40 AM |
| 400+ 5% carbon comp resistors 1/8-2W 1% or better matched pairs available | sdedalus | Swap Meet | 3 | 22nd June 2006 04:31 AM |
| Page generated in 0.08967 seconds (75.70% PHP - 24.30% MySQL) with 11 queries |
