| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm thinking to put volume pots and rotary selector close to the rear panel of my preamp. I've read that I can use a shaft extender made of either a rod, stainless steel tubing or plastic tubing. But, the problem is the front panel where I will install the knob. How can I mount the extender at the front panel "tightly but rotating freely"? Any thoughts on this?
#2 |
There is also a special sleeve bearing mounting accessory that lets you run the extension through the panel with no rattle and good feel.
Like this (AZ30): http://www.schuro.de/Downloads/PDF-P...sverb_I_BR.PDF
UrSv Those who say it can't be done should not stop those who are doing it. |
#3 |
A rubber grommet through the front panel is cheap and easily available.
Eric.
I believe not to believe in any fixed belief system. |
#4 |
Thanks so much for the answer.
Anybody knows a US source for this type of parts? |
#5 | |
Or plastic washer with 0.25" inside diameter from Home Depot.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
| New Bass Extender | amplifierguru | Solid State | 31 | 8th October 2008 07:43 PM |
| USB cable extender or amplifier | jacquesl | Digital Source | 6 | 6th December 2006 05:53 PM |
| Extender PCB's | amplifierguru | Solid State | 7 | 14th December 2005 02:20 AM |
| USB active extender | Risto80 | Digital Source | 0 | 30th October 2005 02:48 PM |
| Page generated in 0.06993 seconds (71.34% PHP - 28.66% MySQL) with 10 queries |
