| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I need a switch to turn on and off my new class D amp.
Will Bulgin MP0045/1E2 do the job? 16mm Switches If so where can I buy one? Thanks,Manos |
#2 |
So you're not the only one that like the look of these ring illuminated switches. It depends on the power supply, if it has a high inrush current, whether it has a soft start circuit, how powerful the amplifier is and what type of power supply it has.
If you've got a soft start circuit the relays will do the switching to the transformer and the switch will only turn the soft start circuit on and off. This is how I've got mine configured, the low voltage softstart circuit also providing an easy way to power the LED in the switch. Often the transient inrush demands of a linear supply will cripple lesser switches, the demanding, large currents at turn on will cause arcing across the closing gap, causing corrosion, this is why a high power switch would be a good idea. You can buy them ebay or from a lot of computer modding shops, as the modders like to replace their PC case switches with them. Doing a google shopping search for 'vandal switch' should give you a few decent results. They are quite expensive however and you will most likely require a resistor before the LED in the switch to prevent it from damage.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#3 |
I have found some beutiful ones in Performance PC.
Have a lookDelrin Vandal Resistant Illuminated Switch Black - Blue Dot Products Model: VSW-BK-DOT-BL [VSW-BK-DOT-BL] : Performance-PCs.com, ... sleeve it and they will come I have read all your posts about IR 2092 module and i have bought 2 IRAUD-150 from the American(classDaudio). Also I have ordered an A1000smps from Connexelectronic and I am going for 2 x 500 w in bridged mode |
#4 |
Yes, those do look quite nice and you'd need a latching version too.
Do observe the contact ratings however, 50mA 24 volts DC. Eeek! If you really want the illuminated switch I would advise you build some sort of relay driven switch. In other words use a 9 volt transformer, rectify this into +12 volts, then place the switch on the the 12V DC line so that it turns on and off a high power relay. That SMPS can deliver 1100 watts continuous which requires a 5amp switch @ 240volts. Metal LED Push Button Switch (Red Ring, Latching) on eBay (end time 15-Sep-10 23:51:26 BST) Are the switches I purchased and they will handle 5 amps at 240 volts. It looks like the seller will also ship to wherever you are too and he has red, blue and green versions, only the front of the switch is brushed aluminium. I can post a picture of mine in operation if you're interested.
#5 |
#6 |
The pictures aren't great, but they give some sort of an idea of what they look like when on.
#7 |
Even though i am a fun of Liverpool i prefer Everton's color for my amp
Thanks pal |
#8 |
You can just about make it out in the pictures, but I've got glowing purple feet on the bottom of the boxes so I wanted a contrast against that. Otherwise I would have chosen blue
#9 |
What do you think about my design?
I'm going to change the box also with a new from modu.italia(Galaxy maggiorato 388) When finished will look pretty professional |
#10 |
Oh I think it looks fine
The only thing you really need to watch out for is proper grounding techniques within the chassis. If there's no hum present you're half of the way there, however with the fast switching going on inside class D amps you have to make sure that any signal ground is free from the high speed switched currents otherwise you can get contamination into the signal ground.
| Top quality main switches for audio-hifi comp (Rotary and Pushbutton Power Switches) | tiefbassuebertr | Parts | 12 | 10th March 2010 04:14 PM |
| switches | JozzaG | Power Supplies | 4 | 10th February 2010 04:56 AM |
| help me to bulgin illumination | Pocoyo | Everything Else | 0 | 15th May 2009 03:51 AM |
| Switches | LizardDefence | Everything Else | 5 | 1st June 2005 08:52 PM |
| A simple way to create dual(or more!) rotary switches out of single rotary switches | stappvargen | Pass Labs | 14 | 16th April 2004 11:33 PM |
| Page generated in 0.11044 seconds (77.99% PHP - 22.01% MySQL) with 11 queries |
