| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Anyone got info on building transformators? Ei-core should be pretty easy to make the core for. But R-core seems to be much better!
Party on Wayne! |
#2 |
i just made some calculations with a program i found:
http://www.hw.cz/software/transforn_...ansformer.html The results seem not to hard to build from: 70*70mm core 1*231 coils primary with 2,16(2,5) mm wire 2*38 coils secondary with 3,5 mm wire the output is 2*38V & 25A (1900VA) and should be just fine for one aleph 2 Can this numbers be correct? I belived it would take more turns for some reason..
Party on Wayne! |
#4 |
Yes i know, but if you take for example 231*4=924 and 38*4=152 turns. Does it any difference in efficiency??
Party on Wayne! |
#5 |
your primary turns at 231 is not bad you'd use more copper though, my calculation for that size of core is 160turns, what this implies is that you will end up with a lower magnetizing current and maybe lower core loss, trade off being, higher copper losses since you'll be using more copper....best efficiency if obtained when core losses equals copper losses, pretty much textbook stuff!!!
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#6 |
Where can i buy ei laminates in europe?
Party on Wayne! |
| Replacing transformator in X-540 | dviry | Parts | 2 | 11th December 2011 12:26 AM |
| Step-Up Transformator | Silberlot | Swap Meet | 0 | 30th April 2006 01:15 PM |
| Transformator volume control???? | Magura | Parts | 20 | 26th February 2004 03:43 PM |
| Permeability of transformator cores. | Gunders | Parts | 5 | 19th February 2003 12:52 AM |
| Page generated in 0.07707 seconds (74.06% PHP - 25.94% MySQL) with 10 queries |
