| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have two boxes of precision resistors from the 60's (says so on the boxes). From what I can tell they are made of a helical metal film on a ceramic body, with press-fitted endcaps and 5 cm (2 inch) leads. The ceramic body is about 2,5cm (1 inch) long.
The resistors are marked 0,5% and are rated 1/2W or 1W for the fat one. The values range from a few hundred to several M Ohm. The thread spacing of the resistive element is roughly the thickness of a fingernail. The logo reads A P with a plus-sign made of a horizontal bar and a lightning bolt. I hooked one 300R 1/2W up to a variable PSU. At 1/2W dissipation it became warm, at 1W very hot, and at 2W the resistor/coating started smoking. Has anyone come across similar devices? Where would you use them? Voltage regulators, anode load, generally in audio signal path,...? I'd guess they have considerable inductance/capacitance. What about voltage drop, how high would you go? For size reference I've added a Vishay Sfernice MRS25 221k 1% 0.6W 350VDC resistor.
Gravity - Making the G since 13.7 billion B.C. |
#2 |
they're probably good to at least 700V
everything else is matter of preference and simple calculus
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
| PRP - Precision "Metal Film" Resistors | Gooch | Parts | 4 | 8th March 2006 09:30 PM |
| Vishay/Dale 1/8W Precision Metal Film Resistors_ERC-55-200 | pinkmouse | Swap Meet | 1 | 11th February 2005 11:25 AM |
| Carbon film vs metal film resistors in a stepped attenuator? | G | Tubes / Valves | 17 | 22nd August 2004 12:22 AM |
| tolerances of 1% metal film resistors | Wagener | Solid State | 12 | 5th May 2004 03:50 PM |
| Metal film resistors or carbon film in a tube amp? | G | Tubes / Valves | 220 | 31st March 2003 01:57 PM |
| Page generated in 0.06333 seconds (68.73% PHP - 31.27% MySQL) with 11 queries |
