Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th August 2010, 03:24 AM   #1
1965GTO is offline 1965GTO  United States
Default Help ID this part / Need data sheet or specs
Hello, this is a thermal switch that is mounted on heatsink. I recognize the old Panasonic/Matsushita logo. This is out of a Proton D1200 Amplifier.
Does anyone have a data sheet or know the specifications on this part? Is it Normally open or normally closed. What degrees celcius is it rated. Voltage?
Any insight would be appreciated.
Old 27th August 2010, 05:20 AM   #2
RJM1 is offline RJM1  United States
From the schematic (see attached ) they would be normally closed since the switches from the two channels are in series, because you would want the amp to go into protection if either switch changed. They would both have to close if they were normally open for the amp to go into protection.
For the temperature I can only guess. The T110 would seem to suggest 110C which seems a little high. I'd suggest something lower like 85C. Voltage, because the chip is run from a 54V supply you would need a minimum of 60V but preferably 150 to 200V.
Old 27th August 2010, 10:22 PM   #3
Thank you for the insight. So something like this should do nicely? See link.
http://www.cantherm.com/products/the...erm_f20e06.pdf
Old 28th August 2010, 04:51 AM   #4
Looks good.
PCF2705P Data Sheet fmak Digital Source 0 23rd May 2007 03:03 PM
looking for old data sheet unclejed613 Parts 3 13th May 2007 06:35 PM
Transformer ID & Specs Sheet Help Trout Tubes / Valves 1 17th January 2006 03:01 AM
Data sheet for B220SS jez Multi-Way 5 22nd March 2005 07:56 PM
data sheet KCC Parts 5 6th January 2004 09:03 PM
Page generated in 0.07759 seconds (72.13% PHP - 27.87% MySQL) with 11 queries
