Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd July 2003, 12:23 AM   #1
jarthel is offline jarthel  Australia
Default help with elma rotary switch 2x24 position
Well I plan to make a stepped attenuator out of it.
My question is, where do I start soldering?
on the front of the switch, there are numbers from 0 to 22. From what I understand, I'll be needing 23 resistors for each pole.
In this diagram from Goldpoint (http://www.goldpt.com/schm_ser.html), there's are some tips on on how to solder it.
My question is, do I start with pin 0 and pin1 as my R1 and so on.
Thank you.
Jayel
Old 2nd July 2003, 12:42 AM   #2
diyAudio Senior Member
fdegrove's Avatar
First of all you should have 23 useable pos. from a 24 pos. rotary, # 24 being taken by the stop.
You probably mean for each deck?
In the case of a series attenuator you should solder 23 R inbetween positions of the switch.So R1 connect from pos. 1 to 2,
R2 from pos. to 3 etc...till you arrive at pos. 23 which normally has no attenuation, so a jumperwire is often used there.
There are better ways to make a series attenuator though.
Frank
Old 2nd July 2003, 01:09 AM   #3
Just a question.
On the rotating part of the switch, there's a "tab" with the letter A in it. It's in position 1 right now (the last position when I turn it counter clockwise).
1 position = 2 pins. In position 1, the first pin of position 1 is ground. right?
The 2nd pin of position 23 is the "input". right?
Thank you
Jayel
Old 2nd July 2003, 01:42 AM   #4
fdegrove's Avatar
Default THE ENTIRE KAMASUTRA...
The idea of a series ladder is to add one resistor in series with another so that at maximum att. the resistor value is a short from input to ground.
IMO, this position is wasted on a rot. switch and best replaced by a mute switch.
Now, assuming you want to build a stereo series att. using a double deck rot you need to define in and output.
In the case of GP series att where are Rs are seried, the input is at the end of the series and the output follows the wiper pos.
I don't know what Elma type you have...but if I read you correctly I think you've figured it out correctly.
Just keep in mind not to wire the whole shebang backwards...that would make for some getting used to.
Frank
Old 2nd July 2003, 01:47 AM   #5
Thanks Frank. You've been vey helpful.
Jayel
ps. that wink of your sometimes make me skeptical
Old 2nd July 2003, 02:18 AM   #6
fdegrove's Avatar
Actually, it should...I know I can't be trusted...Heck, I don't even trust myself nowadays.
The wink emoticon sig originates from one of our mods, namely Peter Daniel who's sense of humour I much admire.
Kinda puts things into perspective, doesn't it?
Happy building,
\The use of another sig emoticon is intended...
Frank
WTB ELMA switch 2x24 positions reaction Swap Meet 3 16th February 2009 08:58 AM
3-pole 4-position Elma Rotary Switch s0rce Swap Meet 0 19th January 2003 02:14 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
