Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Elna Silmic II or Elna Cerafine?
Old 16th August 2010, 12:37 AM   #11
KenTripp is offline KenTripp  Australia
Originally Posted by indianajo View Post
Silk has not been used as a capacitor dielectric since the 1920's, you should look at the datasheet to find out what it really is.
Not pure silk but it's certainly part of the mix.
Aluminum electrolytic capacitors for audio applications - Features of the SILMIC series | ELNA
I prefer Silmic IIs over Cerafines.
Old 16th August 2010, 01:22 AM   #12
mach1 is offline mach1  Australia
Banned
rg12,
I would advise you to get a handle on the sonic signature of various electrolytics before you embark on replacing all those in your amp with just one type. Each type has a different signature which may or may not be to your liking, and if you stick with just one, you are going to hear that signature big-time. Mixing them up a bit may get you the best outcome.
As well as Silmics, I would suggest you consider Panasonic FC, FM and Nichicon KZ. Re the 0.22uF caps (which sound like coupling caps) I would simply replace them with MKP416 (a high quality polyprop film type from Digikey).
Whatever you choose, follow Indianajoe's advice and get the caps fresh from a large supplier.
Old 16th August 2010, 02:17 AM   #13
rg12 is offline rg12
By mixing them up you mean just throw randomly some from one series
and some from another?
The 0.22uf cap is electrolytic, is it ok to replace it with metalized polypropylene?
Whats wrong with hearing the signature of the caps? i thought that
this is the purpose.
Old 16th August 2010, 03:27 AM   #14
KevinLee is offline KevinLee  Canada
Dude, don't worry about putting in different brands/series of caps. As long as they are better than you took out you will be OK.
Old 16th August 2010, 03:38 AM   #15
Yeah i know that, but i feel weird about just throwing some of this and some
of that without thinking what will sound how and where...
Old 16th August 2010, 03:51 AM   #16
Banned
No I mean getting a handle on the sonic signature of various caps and arriving at a mix (or monoculture) that satisfies your sonic preferences. Mine is to try to achieve a level of neutrality with no predominant signature.
Absolutely, so long as its voltage rating is not exceeded.
It may well be your purpose. Mine is to try and diminish the sonic contribution of caps.
Old 16th August 2010, 03:54 AM   #17
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Unfortunately the reality is, that unless you have Two amps and make changes to one cap at a time, and can do proper A/B comparisons, you really never will know which cap made what difference if any. Even that is flawed, as it may be an interaction between multiple components that will have an effect.
When I did my amp, I did feel it sounded different and better, but I have no way of knowing whether it really did, or if it was a purely pshyco acoustic effect or even just inability to correctly remember how it previously sounded.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 16th August 2010, 03:57 AM   #18
About the mixing thing...i don't understand how can i test and achieve that.
To hear a cap i need to solder it, so how exactly is it done?
Old 16th August 2010, 04:35 AM   #19
Now im stuck...because using the same series for the whole amp isn't
recommended and even if i choose lets say two or three different brands or
series for the amp, i wouldn't know how to split them.
Here's the schematic for the amp and a pic of the top of the amp:
http://www.milkbands.co.il/Pioneer-SA-7300-int-sch.pdf
http://www.milkbands.co.il/P8080006.JPG
If someone maybe can take a look and tell me how to devide the sections
so i wont just throw one cap here and another brand there and make the
channels uneven or something.
Thanks alot so far.
Old 19th August 2010, 01:13 AM   #20
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
silmic used near transistor better than cerafine
(100uf)
for supply (DC) 470uf or 330uf cerafine better
if used silmic you will feel bass influence a little bit
(looks for the caps after transformer)
if you have more budget go to bg std, f, fk or n
hope u success
Elna Silmic II or Elna Cerafine?Hide this!Advertise here!
FS elna silmic II,cerafine,nichicon muse,balck gate back Swap Meet 9 11th June 2010 04:25 PM
Elna Silmic & Cerafine Large Reservior Caps Fanuc Swap Meet 3 15th March 2010 09:29 AM
WTB Elna silmic,cerafine capasitors elviukai Swap Meet 2 4th December 2005 12:29 AM
Copyright ©1999-2017 diyAudio
