| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I wrote the uf and voltage of all the caps im going to replace in my amp
so i will have a clear list of what i need to order. I got one Sanyo electrolyt saying 2,2/10 does that mean it's 2.2uf 10v? Why is it a ',' and not a dot between the two 2's? and i got another two very small Sanyo electrolyts (half the size of the one i mentioned above) looking like that: http://www.milkbands.co.il/exmp.JPG Why is the dot before the 22? is it 2.2uf 10v? and if it is, why is the cap much smaller than the one with the same uf and volts from the one i mentioned above? Roi. |
#2 |
In Europe for example we use a "," instead of a "." for decimals.
So 2.2uF would be written as 2,2uF. Another way to write 2.2u is 2u2. 2,2uF 10V sounds like a coupling cap of some sort. Would it make sense to have a 10V cap in this position? .22 is most likely 0.22uF, often written an u22, or 220n.
Gravity - Making the G since 13.7 billion B.C. |
| Selling Sanyo OS-CON 620uF 6.3V capacitor | spencer | Swap Meet | 9 | 9th January 2008 03:37 PM |
| FS: Sanyo OSCON SP SEP SEPC Series Caps | Orb | Swap Meet | 1 | 23rd September 2005 01:54 PM |
| FS: Sanyo OS-CON SP Series Caps | Orb | Swap Meet | 6 | 29th June 2005 03:16 PM |
| Sanyo OS-CON SP series 180uf/20v Caps for digital projects, etc. | KBK | Swap Meet | 1 | 21st February 2005 11:15 PM |
| Sanyo MV-AX caps. Any good ? | Elberoth | Digital Source | 1 | 24th December 2004 04:42 AM |
| Page generated in 0.06894 seconds (67.85% PHP - 32.15% MySQL) with 10 queries |
