| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I got my amp's schematic sheet and for every cap or resistor there is a number, for example c29 0.001 is a cap.
Is there a way i can buy a component by part number? or how does it work? |
#3 |
How can i calculate this to get the farads in uf? and how can i find out
how many volts? |
#4 |
fractions are usually uf. uf is the modern way to abbreviate microfarads, before 1980? microfarads was usually abbreviated mf. .0002 uf 1960's style is now sold as 200 nf. 1-900 can be uf if power supply cap or input coupler cap, if a roll off or filter cap more likely to be nf (nanofarads). RF bypass caps are 1-900, usually in pf. If you make the cap voltages higher than the power supply voltage, you will be safe, usually. Good luck.
If you want more guidance, scan and post your schematic, and we'll guess which cap is which function.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 Last edited by indianajo; 11th August 2010 at 02:35 PM. |
#5 |
So i guess all the nf caps are disc caps?
#6 |
Surplus and sixties manufactured caps in the .0002 mf size etc ( 200 nf) will be rolled paper or plastic film. nanofarad caps can be disc, which is usually ceramic, or rolled film. John curl hates ceramic disc caps for audio coupling and filtering, has some data to prove his adversion, so buy film ones to make him happy. ceramic disk is mostly for radios, power supply bypass, picofarad ones for RF oscillation prevention. I've used ceramic disc in violation of his rules, but I used 50V ones where the signal was probably under a volt, so probably the non-linearities were swamped by the huge voltage rating. 50V ceramic disk caps aren't cheap, but they are so tiny it is cool to put them where electrolytics used to go and never do it again..
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 |
#7 |
Will go with film, thanks alot.
| What does the dot behind a part number mean? | wwenze | Parts | 12 | 27th October 2010 01:04 PM |
| Fet dravers part number? | Bad silver | Car Audio | 2 | 22nd June 2009 05:52 PM |
| Jfet part number | mmerig | Parts | 5 | 23rd September 2007 04:19 PM |
| Need part number for a transformer | bluegti | Chip Amps | 16 | 27th December 2006 03:06 AM |
| Page generated in 0.09533 seconds (82.73% PHP - 17.27% MySQL) with 10 queries |
