| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I would like to replace the two power caps in my Pioneer SA-7300 amp.
The corrent caps are 8000uf 50v. I heard that good caps are Mundorf and Cerafine Elna but im open for suggestions. I would like to know where can i get the recommended caps and their average price if possible (i need international shipping). Regards, Roi. |
#2 |
Well they might be labeled as "8000 uF". But electrolytic capacitors almost always have a very wide manufacturing tolerance. So they might have been quite different from 8000 uF, even when new. You might be able to find a possibly-standard 8200 uF labeled value at 50V or higher. But 10000 uF is much more common and should be close-enough.
I would be nice if you would enter the country you are in, in your profile. It would enable people to point you toward the most-appropriately-located sources of supply. If it were me, I would probably just look at mouser.com or digikey.com and pick some low-ESR caps with high ripple-current ratings that had the proper values and voltage ratings. But I'm fairly certain that someone who specializes in hearing the differences between power supply capacitors will chime in with some opinions, any minute now. Cheers, Tom |
#3 |
I don't want to risk my amp with higher uf, i was told that it can burn the
bridge if i put caps with higher uf than the stock if i don't replace the bridge diods. |
#4 |
As mentioned by gootee, tolerances are wide
the standard values are 6800 and 10000, you may find 8200uf but not common. The amp would have been designed for worst case tolerances at the time so I'd be happy to fit a high ripple/low esr 8200 or 10000uf cap as a replacement. |
#5 |
I have stock on some Samwha 8200Uf 100V Snap-In caps
1 1/2 dia X 2" Tall http://www.apexjr.com/images/Samwha8200.jpg there $3.00 Usd each Also have 10,000Uf 50 Volt Nichicon Radial caps 1" dia X 2" Tall p/n UVR1H103MRD at $2.99ea Steve @ Apex Jr. |
#6 |
I checked my amp power caps and they have 4 legs, while the other caps i have seen has only two.
Another thing is that mine are 35mm diameter. Which brands except mundorf are good for amps and what is considered a low esr and what is considered high ripple? (i have no idea what those two things mean, but i guess it's important). |
#7 |
For PSU caps what is termed "Computer grade" have high ripple and low ESR. Ripple is to do with the current being taken and esr is the resistive loss. Someone with more knowledge then me will no doubt provide a technical explanation. For PSU caps a high ripple is usual.
like these computer grade cap 4 terminal is usually two terminals for the + & - and two other to help with fixing- usually not connected. the ones from apex are a 4 terminal type from the images |
#8 |
Most of the caps i have seen in most websites doesn't write the ESR and ripple, so what can i do?
About the diameter, are the connections in the same position in all the caps or the cap diameter changes the distance between the connections? Do i need computer grade or audio grade? I decided to go with 10000uf, what brands and models are recommended? I have never tested caps with my ear like most of you guys in this board, so what is mostly preferred? |
#9 |
I just checked the distance between the connectors of each power cap and
it's 15mm. I couldn't find caps with that connector spacing, please help! |
#10 |
I've had good luck with the high end Nichicon, Elna, or Nippon ones. Like someone else pointed out, mouser and digikey are great ways to look for them since they have very detailed advanced search functions that let you narrow down your choices by a lot of parameters, and both of them usually list ESR. If anything, look at similar caps' datasheets since the datasheets are usually for a series of caps-if you find one that you like but that is a little too small, you could probably find the part number for an alternate size that is otherwise identical on the sheet.
| 8000uF MKP Caps for Krell MRA = Master Reference Amplifier - Schematic wanted | tiefbassuebertr | Solid State | 11 | 8th June 2011 12:14 PM |
| Looking to replace 6800uF 50V filter caps | FickleBJT | Solid State | 6 | 7th March 2010 06:56 PM |
| Sprague Caps 16000uF/50V | WALTER BURKHARD | Swap Meet | 1 | 25th February 2005 05:42 AM |
| 35,000u/50V Mallory caps | Peter Daniel | Swap Meet | 2 | 7th March 2003 12:37 PM |
| 4,700/50v ROE caps | Peter Daniel | Swap Meet | 0 | 7th February 2003 05:50 PM |
| Page generated in 0.10024 seconds (87.45% PHP - 12.55% MySQL) with 10 queries |
