| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm scrounging through recycled parts to find suitable inductors for a PS CRC filter for my tube IGC (see JLTi thread).
Is one of the following types of inductors more suitable for a CRC filter (other than the obvious differences in inductance and compactness)? The one on the left is from a speaker crossover and measures 0R6, and the one on the right is from a switching PS and measures 0R3:
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
You mention tubes (though I don't find the thread on that board); I can only assume your power supply will operate on 50 or 60Hz.
The chokes shown are for filtering HF; the speaker crossover for cutting high-F audio, the line filter for >50kHz to remove line noise from switching supplies, which would otherwise put unacceptable junk upstream of the supply. You need a choke which looks more like a transformer, one with an iron core. Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 |
diyAudio Moderator Emeritus
Leadbelly,
The one on the right is a common-mode-choke. Here are some threads on these. Using common mode chokes in filament supply. Could this be the perfect coils for Aleph's PS?
Rodd Yamashita |
#4 |
Thanks.
Well, it sounds like neither of those is very good. Would another inductor from a xover work, one with a laminated steel core? This is for the tube IGC in Chip Amp forum. Draw is on the order of milliamps, so I just want to recycle something from the tons of parts I have.
| Differences between X0 and X0.2 | rsbay | Pass Labs | 2 | 27th March 2010 03:40 PM |
| Differences between TMM and MTM configuration | ttan98 | Multi-Way | 2 | 23rd March 2007 01:27 AM |
| Amps, are there differences? | Stuart Easson | Car Audio | 18 | 30th October 2004 10:43 AM |
| What is the differences between | Richard Moon | Multi-Way | 2 | 23rd September 2002 12:46 PM |
| Page generated in 0.07826 seconds (74.39% PHP - 25.61% MySQL) with 11 queries |
