| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm working on my power supply. It's for a hi-quality mic preamp. The stages are all balanced, so will reject some hum/noise.
I'm looking at capacitors on-line. Some of them are SO expensive. Black Gates for example. Why are they so expensive? Why not some LCR's from Mouser? Or some of the computer grade electroclytics? Can some of you recommend the best filter caps? I'm actually looking at non-polarized Solen caps. They seem to be mid-priced (I guess I want to stay away from anything TOO cheap). The power supply is a VERY simple cap -> choke -> cap arrangement. Thanks for any help! Matt |
#2 |
In my opinon......
Your preamp/amp/speaker never gets better than the sum of all the components.... So if you really want to pay a huge amount of money for special caps, then you must also calculate for costs for high grade components in rest of your system..... I proberly get a lot of "spanking" from the "Magic Cap" fans in here for this statement, but so it be...
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
Hello,
I would stay away from budget polypropylene and go for a choke-input filter cosisting of a choke, a paper in oil then a Black Gate then another choke or a resistor then another Black Gate. You can buy Black Gate at Soundshop Big in Japan. Very accurate service and real cheap compared to other suppliers outside Japan. I have 9 47 microfahrad 630 volt SCR ( = Solen ) in an alumium can which have been replaced by B.G.. If you can help me next time i need to order in the States i am willing to sell in return for 9 dollars each. Yours sicerely, Ed |
#4 |
SMPS circuits are really hard on the components ... of course they are, that way they can get away with fewer, making them cheaper for the masses... So naturally the components are tough. Pull some caps from a computer PSU, connect them in series if need be, and have a ball. No need for money in my book.
Tim |
#5 |
Hello MW Mitchell,
I am a big fan of Elna Cerafine for power supply filtering. I have (2) 22,000uf in my 30 watt per channel integrated. I will usually parallel a smaller better quality film cap or a better electro as well. I like Sanyo Os-Con in my CD player. I have not yet tried Black Gate, but I hope to soon. I believe in the law of dimishing returns. If I use a cap that costs for example $10.00 and I get 90 or 95% of the performance of a $50.00 cap, I am happy. I would rather spend my extra money on a nice Cabernet or a bottle of port. Cheers KevinLee |
#6 |
Hello,
I seriously think you should give the Black Gates WKZ a try or go for the Allen Wright or another shunt regulation. Or combine the two of them like i did. Yours sicerele, Ed |
#7 | |
When you say "filter Caps" do you mean the mains supply, or for low pass filtering (or similar)? If you're talking about mains supply use several types of caps. For bulk power storage, electrolytics from panasonic are good. (I like the FC series). Then bypass them with some tantalium electrolytics and ceramics for higher frequency response. For anything in the audio path... ...You may want to use COG type ceramics. the X7 and Y5 types change value with applied voltage (this is a bad thing when building a active or passive filter). -Dan
-With a bad amp, everything sounds the same. It takes a good amp to tell the difference between true "Artists" and the rest of the "Performers". |
#9 | |
#10 |
And pls don't get me wrong; I am not questioning the validity of the above (or other) recommendations; it just happens to me too that I sometimes use a first rate component without first bothering to check for any audible difference ...
Makes me feel happy though
| I'm anti-expensive audio parts but man, a good capacitor can make a difference | jduffy | Tubes / Valves | 6 | 25th April 2007 04:13 AM |
| Which caps make the most audible difference? | TDWesty | Solid State | 5 | 31st January 2007 05:49 PM |
| One way to make expensive speaker cables! | jam | Everything Else | 132 | 23rd October 2004 05:47 AM |
| How difficult and expensive is to make PCB for your DAC? | machinow | Digital Source | 7 | 30th October 2003 08:17 AM |
