| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 | |
A good analogy is a 9 volt battery. Whether new or flat, the battery still reads essentially 9 volts off load. What has hapened is that the internal resistance of the battery has increased, and a similar thing happens with electroylitics. You still have a 2200uf or whatever cap, but as it fails it's like a resistor of ever increasing value gets added in series with it.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#12 |
It's glue, but I would replace them anyway. I would replace them with the largest caps that will fit on the board, maybe 4700u/50v. Always a good idea to go up in value when replacing PS caps, especially in a subwoofer. Also silicone them to the board, as they will be subjected to a lot of vibration.
Dave |
| Glue! | johnr66 | Construction Tips | 9 | 11th May 2010 03:24 AM |
| What glue to use? | wixy | Multi-Way | 26 | 6th February 2007 11:49 AM |
| Electrolyte Leakage? | TrevorK | Parts | 3 | 6th July 2006 03:44 PM |
| MKP VS Electrolyte | TunaFish | Tubes / Valves | 9 | 7th July 2004 01:31 PM |
| bi-polar vs. regular Electrolyte cap | tomchaoda | Parts | 3 | 22nd April 2004 06:14 AM |
