Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
845 tube - pins have 4 collet connections
Old 19th July 2010, 10:14 AM   #1
mreichler is offline mreichler
Default 845 tube - pins have 4 collet connections
Someone makes a set of collets used in connections to the 845 tube.
Each collet has a solder connection and is then attached by using a small pair of open ended wrenches. Seems to be the perfect connection.
Do not really like the twist connectors.
I have lost the web address for the supplier.
Can anyone help?
Thanks in advance.
mreichler.
845 tube - pins have 4 collet connectionsHide this!Advertise here!
Care and Feeding of Tube Pins / Sockets gingertube Tubes / Valves 22 14th February 2012 08:33 PM
845 tube question franksmith Tubes / Valves 7 25th September 2009 11:42 PM
Help cleaning tube pins astouffer Tubes / Valves 10 11th December 2007 08:51 AM
what's the purpose of pins 3 and 7 in an 8pin VR tube? jarthel Tubes / Valves 7 9th May 2007 02:42 PM
Cleaning oxidised tube pins. JoeBob Tubes / Valves 18 21st August 2002 04:18 AM
