| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Anyone feel up to identifying the diode I need? I've attached three .jpg files containing the power board schematic of a Philips HTS3357 surround sound system that someone gave me. It won't power on. The zener(?) diode, ZD908, is burned and broken and I want to replace it.
Don't be too tough on me. I have no clue what I'm doing. I just figured since the unit didn't cost be anything, there would be no harm in trying. Thank you in advance for taking the time to help. Thanks, Connie |
#2 |
A schematic diagram would be helpful. Zener diodes often have clues in their type number as to their characteristics. Perhaps that's a 9 Volt? Google it to see. Replace it with the same voltage, and at least as much power rating.
#3 |
Sorry... here's the circuit diagram.
#4 |
Sorry, .jgp's were misidentified.
#5 |
Schematic didn't blow up enough for me to see the numbers. If you can download the datasheet for that IC the zener is attached to by putting the number in datasheetcatalog.com, then maybe that datasheet will tell you what is expected to go on pin 11-12 of that IC.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 |
#6 |
For me me, it looks like it is part of the regulated supply. 5, 12 or 27 volts.
Trace the circuit and find out if it is. Then it is easy to know the value. Gajanan Phadte |
#7 |
On the schematic it clearly states 12V right above ZD908. Just pick a 12V zener diode with the same size (package dimensions).
| Diode specs needed | terranigma | Parts | 3 | 29th May 2010 11:01 AM |
| looking for a diode... | rtate | Solid State | 1 | 21st March 2008 11:10 PM |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| Is it a Diode? | imix500 | Parts | 14 | 28th June 2004 12:17 PM |
| Page generated in 0.08972 seconds (75.52% PHP - 24.48% MySQL) with 11 queries |
