Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th July 2010, 07:27 PM   #1
pdul is offline pdul  Denmark
Default fusible resistors
Anybody who knows a source for fusible resistors in Europe, Where you can shop as a private person?
Old 11th July 2010, 07:33 PM   #2
Did it Himself
richie00boy's Avatar
I have bought some from Farnell.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 12th July 2010, 04:44 PM   #3
Thanks. But unfortunately the Farnell i know of, Will only accept businesscostumers, And I am only a poor private solderiron swinger.
Old 12th July 2010, 04:53 PM   #4
Did it Himself
What value do you need? The ones I got were I think 2.2 ohm, 1 watt. I have no use for them now so if they are what you need you can have them.
Old 12th July 2010, 05:06 PM   #5
Thanks for your kindness, But I need some 33 ohm, 1/4 watt. It is for an old amplifier, I am restoring. Maybe you know of an alternative solution/component?
Old 12th July 2010, 08:58 PM   #6
Spiny is offline Spiny  United Kingdom
Spiny's Avatar
both CPC and RS stock fusible resistors but not in that value Farnell seems to hold 2watt ones not 1/4 watt.
As a note, I've never had a problem buying online from farnell as a private individual, buy through the web and they accept credit cards
The tyco part is FRN25J33R 33R 0.25watt wire ended. Quite where you would get a small quantity (1 or 2 ) I don't know
Old 12th July 2010, 09:04 PM   #7
Did it Himself
I think the rest of world Farnell still has to catch up with the UK Farnell...
Old 15th July 2010, 01:37 AM   #8
indianajo's Avatar
Default Farnell
The US division of Farnell, Newark.com, is selling to me a complete nobody (with 40 years in electronics under various employers) with no minimum buy. They are even shipping to me like it was a business address, Euro 3 minimum via UPS. What is wrong with (I don't know flags except olympics) Norway? The US Newark before Farnell bought them used to have a business only policy, but when I logged on the website and furnished a debit card number with cash behind it, no problem.
As far as easy fusing, look at the wire tables in the National Electric code. Fusing current for 30 ga is about 1 amp and it goes down from there. You can look in the Belden or alpha catalog, figure out what the 7 strands of wire are in your 24 ga wire scrap from a PC power supply, strip out a single strand, solder 2 cm between two terminal strip lugs, instant low value fuse. Don't try this on mains wiring, use a real registered fuse and fuse holder.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 15th July 2010, 02:15 AM   #9
Speedskater's Avatar
I don't think that fusing current for 30 AWG is 1 Amp. As it can carry 2 Amps with PVC insulation and 4 Amps with Teflon insulation (80C & 200C).
My fusing current chart does not go to that small a wire. But if I did my mental math correctly, 30AWG should fuse at just about 7 Amps.
I didn't think that NEC listed fusing currents.
Kevin
Old 15th July 2010, 02:31 AM   #10
indianajo's Avatar
use the chart in the NEC, not my memory. I'm putting single strands in the transformer feeds to rectifier tubes. You can't even buy fuses rated that small, (200 ma) and they are certainly not rated for 475 V. 1/4 x 1 1/2 fuses only go up to 250 VAC. New rectifier tubes are not as failsafe as they were in the 1960's, and 475 v transformers are way more expensive.
5 Watt Resistors on Aleph 4 and Holco Resistors nicharis Pass Labs 16 8th February 2012 07:50 AM
What resistors are we using ? a.wayne Multi-Way 1 19th July 2010 08:23 AM
FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers chris-man Swap Meet 1 28th May 2009 11:47 AM
Inductive resistors for source resistors bbakota2000 Pass Labs 12 25th March 2005 11:33 AM
Weird Resistors, anyone know anything about resistors priscared Parts 1 19th March 2004 11:59 AM
Page generated in 0.10155 seconds (75.21% PHP - 24.79% MySQL) with 10 queries
